cgal-discuss - Re: [cgal-discuss] Convert Alpha-Segments to an ordered Polygon
  • To:
  • Subject: Re: [cgal-discuss] Convert Alpha-Segments to an ordered Polygon
  • Date: Mon, 06 Jun 2011 14:07:57 +0200
Edge is a std::pair<Face_handle,int>
From the face you can get the two vertices
with index different from the index in the pair.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TDS_2_ref/Concept_TriangulationDSFaceBase_2.html#Cross_link_anchor_1316
andreas
On 06/06/2011 13:27, Markus Eich wrote:
Thank you for the input. My question is now how can I access the
neighbors of an edge using CGAL?
Is there an overridden function like as.segment(*it).get_neighbor() ?
The link
doesn't tell me anything (sorry i am a CGA newbie). If I have the
segment A from the Alpha_shape_edges_iterator, how can I get the
adjactend Vertices. How can I extend my little example to get the two
adjacend edges?
for(Alpha_shape_edges_iterator it = as.alpha_shape_edges_begin();it !=
as.alpha_shape_edges_end(); ++it) {
segments.push_back(as.segment(*it));
Cheers,
Markus
On 06.06.2011 08:55, Sebastien Loriot (GeometryFactory) wrote:
Markus Eich wrote:
Dear all,
I am using CGAL in order the get one or more alpha polygons from a
shape. IN a first approach I assume there are no holes. I generate
the segements as follows:
Alpha_shape_2 as(lp.begin(),lp.end());
// find optimal alpha value
Alpha_iterator opt = as.find_optimal_alpha(1);
as.set_alpha((*opt)*2.0f);
as.set_mode(Alpha_shape_2::REGULARIZED);
std::vector<K::Segment_2> segments;
std::vector<K::Segment_2> sorted_segments;
!= as.alpha_shape_edges_end(); ++it)
std::cout << segments.size() << " alpha shape edges" << std::endl;
This works fine an I get all the segments. My problem is that I need
a single polygon (in my example I only have one concave shape). If I
iterate over the std::vector<K::Segment_2> segments vector, the
segments are like E,A,V,D,C,F , instead of A,B,C,D,E,F. In need the
segments in an ordered way i.e. that the .target() of A is the
.source() of B, the .target() of B the source of C, and so on.
How can I achieve this using CGAL? Is there a way to sort the
segments directly?
There is nothing to do it directly in CGAL.
This is a simple graph problem: each edge has 2 vertices and two
adjacent edges share one identical vertex. In particular each such
vertex is adjacent to two other vertices. Starting from one vertex
and going from adjacent vertex to adjacent vertex you can reconstruct
the polygon.
You can use for example a
std::map<Vertex_handle,std::vector<Vertex_handle> >
to get the adjacency between vertices.
For the definition of an edge as std::pair<Face_handle,int>, see:
S.
Thank you and cheers,
Markus
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
