- To:
- Subject: Re: [cgal-discuss] Surface Meshing
- Date: Thu, 16 Jun 2011 11:56:35 +0200
On jeudi 16 juin 2011 00:30:05 Arun Ramasamy wrote:
> Hello,
> I'm using CGAL's Surface Mesher to extract Isosurfaces from volume
> datasets. The API works many times. However it fails equally often with an
> exception thrown in the method 'private_test_point_conflict_impl' at
> line#248 in
> CGAL/Surface_mesher/Surface_mesher.h. The error message that I get says
> that a 'point is already inserted on surface.' Is it alright to ignore
> this error message (I made CGAL throw exceptions on assertion failures). I
> see this only when the data gets a bit noisy.
On lundi 13 juin 2011 16:08:16 Arun Ramasamy wrote:
> Hi, I'm currently attempting to extract iso-surface from a volume data-set
> using the 3D Surface Mesh Generator API. This API works for some of the
> iso-values. However, it fails for other values and doesn't terminate. It
> seems like it fails when there are outliers for the given iso-value (eg/
> like a sphere inside another sphere).
> Is it possible to either
> a. Make the algorithm ignore the outliers if it not connected to the
> 'correct' closed surface around the center of the bounding sphere. or
> b. Make the algorithm extract multiple disconnected closed iso-surfaces
> from the data set. or even
> c. Terminate with failure if it detects something wrong with the
> data-set/oracle.
> Other ideas are welcome too. Thanks.
Hi Arun,
So far I had not found time to reply to your mail of last Monday. Sorry.
If your 3D image is a bit noisy at the iso-value you specify, then it can be
impossible to create a manifold iso-surface from it. You should use the tag
CGAL::Non_manifold_tag() instead of CGAL::Manifold_tag().
Laurent Rineau, PhD
- [cgal-discuss] Surface Meshing, Arun Ramasamy, 06/16/2011
- Re: [cgal-discuss] Surface Meshing, Laurent Rineau (GeometryFactory), 06/16/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] Surface Meshing, Arun Ramasamy, 06/16/2011
