- To:
- Subject: [cgal-discuss] Edge sewing
- Date: Thu, 16 Jun 2011 07:23:59 -0700 (PDT)
Hello,
I am using CGAL::Polyhedron_3 to work on meshes, specifically on meshes with
topologic problems.
I need to simply merge two edges. Those edges are identically in geometry
but are duplicated in the HalfedgeDS. So that, it is considered as a border
edge.
There is nothing about edge sewing in Euler operations.
There could be a solution by accessing directly the HDS (but dangerous).
Is there any solution to that problem?
Thanks
Charles
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Edge-sewing-tp3602627p3602627.html
- [cgal-discuss] Edge sewing, Charles, 06/16/2011
