cgal-discuss - [cgal-discuss] Meshing 3D Gray Level image problem
  • To:
  • Subject: [cgal-discuss] Meshing 3D Gray Level image problem
  • Date: Thu, 16 Jun 2011 14:01:11 -0700 (PDT)
Hi,
I'm implementing code from Chapter 46 - 3D Surface Mesh Generation.
I've ran the skull case and was able to obtain the mesh. I have created my
own INR files, based on simple geometries. Upon viewing these INR files
in MedINRIA they appear to be 'watertight'.
However when executing the code, it stalls at the line which calls
CGAL::make_surface_mesh. I have made sure my gray level in the file
and target gray correspond, ensured the bounding sphere encompasses
the shape and also that its center is inside the surface.
What am I missing?
Thanks in advance,
m
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Meshing-3D-Gray-Level-image-problem-tp3603769p3603769.html
  • [cgal-discuss] Meshing 3D Gray Level image problem, mylesth, 06/16/2011
