- To:
- Subject: Re: [cgal-discuss] Static gmp libraries for Windows
- Date: Fri, 17 Jun 2011 07:17:40 +0200
On 16/06/2011 22:05, Hamid G wrote:
Hi
I was wondering if you guys could also provide static gmp libraries with
CGAL's Windows installer.
Right now, libgmp.lib is an import library that calls libgmp.dll so I
can not create a truly standalone executable application.
As a side question, is it possible to combine an import library with its
.dll so when I link my code against it, I get a full static executable
that doesn't need a separate .dll to be shipped with it.
thanks in advance,
Hamid,
GMP is distriuted under the LGPL, and it must be a dll according
to this open source license.
I would like to remind you that CGAL is also distributed under an
open source license, which is even stronger than the LGPL: If
you distribute binaries you also have to distribute the source
code of your application as open source software. Otherwise,
you need a commercial license for the CGAL components you use.
Best regards,
Andreas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Static gmp libraries for Windows, Hamid G, 06/16/2011
- Re: [cgal-discuss] Static gmp libraries for Windows, Andreas Fabri, 06/17/2011
- Re: [cgal-discuss] Static gmp libraries for Windows, Joachim Reichel, 06/19/2011
- Re: [cgal-discuss] Static gmp libraries for Windows, Giles Bathgate, 06/19/2011
- [cgal-discuss] Re: Static gmp libraries for Windows, Hamid G, 06/20/2011
- Re: [cgal-discuss] Re: Static gmp libraries for Windows, Giles Bathgate, 06/20/2011
- Re: [cgal-discuss] Static gmp libraries for Windows, Andreas Fabri, 06/19/2011
