cgal-discuss - Fwd: [cgal-discuss] Find the perimeter of a shell with no volume
  • To:
  • Cc:
  • Subject: Fwd: [cgal-discuss] Find the perimeter of a shell with no volume
  • Date: Sun, 26 Jun 2011 09:04:45 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=XeBjDvl7vIput75R4hBbwI9VWXbc00ViHN9VS8u76vfq1yGEmopb9kgs/oicLKOBpZ BIijoOMRcU5IxroHPoKAzjJX1diPdbJ7WAXkSzgbBoVHYl66441vqR8eOv0Gxv+CslNe XTve6G3XKxr7kt4WoUJNGAZ1AVfXlfMj7UjBA=
On 24 June 2011 20:49, Giles Bathgate
>What I would like to be able in to do now in addition to my original
>request is to list the halfedge vertexes in clockwize order.
>What is the easiest way to achieve this.
Well, I have managed to get the halfedges out in the correct order:
http://git.rapcad.org/cgit.cgi/rapcad/commit/?id=e39711286195eef79b6feda3bb03fe06c3d1e011
http://git.rapcad.org/cgit.cgi/rapcad/commit/?id=0a5eed8e2b1ae6f56cc8c1144c22edd4151dd415
but sometimes they are oriented clockwize, and other times counterclockwise.
This is okay, if for example I can capture the orientation within a
normal, is there an easy way
to find the normals.
Another thought is prehaps you can see a simpler way to do the whole
thing witch is to linear extrude my original polyhedron.
>Nef_polyhedron_3 consisting of a pair of non coplanar facets.
>The facets share an edge.
>For example if you have the vertices in [x,y,z] notation.
>a=[0,0,0], b=[0,10,0], c= [10,0,0], d=[10,10,2]
>and the triangles [a,b,c] and [b,d,c] they both share the edge from b to c.
and similar nef surfaces.
I did see some code somewhere writtern to achive this using HDS
modifier but I didn't understand how it worked.
Regards
Giles
