cgal-discuss - [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
  • To:
  • Subject: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
  • Date: Sun, 26 Jun 2011 06:13:35 -0700 (PDT)
tl;dr: see subject line
Following a little explanation what I try to accomplish and why.
I have a Regular_triangulation_3 rt and want to extract the power diagram
cell by cell (and only the finite ones).
My algorithm is basically as follows:
CellContainer cells
foreach finite_vertex fv in rt:
foreach incident_cell ic to fv:
check if ic is infinite.
if no_infinite_incident_cell_found
MyCell mc
foreach incident_vertex iv of fv:
MyFacet mf
get edge e with rt.is_edge(fv, iv, ...)
circulate over incident_facets if of e:
Segment_3 s = (Object cast and so forth) rt.dual(if) // [1]
mf.addEdge(s)
mc.addFacet(mf)
cells.addCell(mc)
[1] at this point I sometimes get a Segment_3 s with identical s.source()
and s.target(). How can this be, and what can I do about it? This makes
really no sense to me... :)
Thank you for you time reading this and I hope someone can help me; any tips
and suggestions are much appreciated!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Why-does-Regular-triangulation-3-dual-Facet-f-sometimes-return-a-edge-with-identical-source-and-targ-tp3625888p3625888.html
