- To:
- Subject: Re: [cgal-discuss] "wrong handle" error when running convex_decomposition_3
- Date: Mon, 27 Jun 2011 10:39:49 +0200
This is a known issue already fixed.
Attached is include/CGAL/Nef_S2/SM_point_locator.h patched.
Sebastien.
Nicholas Mario Wardhana wrote:
Hi all
I am trying to do convex decomposition given a closed boundary mesh.
In particular, I am using the code written in:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Convex_decomposition_3/Chapter_main.html
to decompose some models delivered in CGAL package. I have tested
different kernels, namely
CGAL::Exact_predicates_exact_constructions_kernel and
CGAL::Cartesian<CGAL::Gmpq>. It turned out that actually only a few
meshes can be decomposed into convex partitions, for example cross.off
and star.off, which are both of genus 0, and only possess a few
vertices, edges, and facets (each below 100). For other meshes, even
though they satisfy the precondition (I ran is_bounded() to know
whether a Nef Polyhedron is bounded, and many of these meshes are
bounded), the code fails and gives the following error:
CGAL error: assertion violation!
Expression :
File :
D:\nixx\Project\Testbed\dependencies\CGAL-3.8\include\CGAL/Convex_decomposition_3/SM_walls.h
Line : 363
Explanation: wrong handle
Refer to the bug-reporting instructions at http://www.cgal.org/bug_report.html
I am wondering whether anybody knows what causes the error. FYI, I am
using CGAL 3.8, Visual Studio 2008, and Windows 7.
Thank you.
Best regards,
Nicholas
PS: sorry for sending two e-mails in less than 1 day, I just started
using this particular module and got confused
// Copyright (c) 1997-2000 Max-Planck-Institute Saarbruecken (Germany). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you may redistribute it under // the terms of the Q Public License version 1.0. // See the file LICENSE.QPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/trunk/Nef_S2/include/CGAL/Nef_S2/SM_point_locator.h $ // $Id: SM_point_locator.h 60172 2010-12-06 15:01:15Z afabri $ // // // Author(s) : Michael Seel <> #ifndef CGAL_SM_POINT_LOCATOR_H #define CGAL_SM_POINT_LOCATOR_H #include <vector> #include <CGAL/basic.h> #include <CGAL/Unique_hash_map.h> #include <CGAL/Nef_2/geninfo.h> #include <CGAL/Nef_2/Object_handle.h> #include <CGAL/Nef_S2/SM_decorator_traits.h> #undef CGAL_NEF_DEBUG #define CGAL_NEF_DEBUG 47 #include <CGAL/Nef_2/debug.h> namespace CGAL { /*{\Moptions print_title=yes }*/ /*{\Manpage {SM_point_locator}{Decorator} {Naive point location in plane maps}{PL}}*/ /*{\Mdefinition An instance |\Mvar| of data type |\Mname| encapsulates naive point location queries within a sphere map |M|. The two template parameters are specified via concepts. |SM_decorator_| must be a model of the concept |SMDecorator| as described in the appendix. |Geometry_| must be a model of the concept |AffineGeometryTraits_2| as described in the appendix. For a specification of plane maps see also the concept of |SMConstDecorator|.}*/ /*{\Mgeneralization Decorator}*/ template <class SM_decorator> class SM_point_locator : public SM_decorator { protected: typedef SM_decorator Base; typedef SM_point_locator<SM_decorator> Self; typedef typename SM_decorator::Sphere_map Sphere_map; public: /*{\Mtypes 5}*/ typedef typename SM_decorator::Decorator_traits Decorator_traits; typedef typename Base::Mark Mark; /*{\Mtypemember the attribute of all objects (vertices, edges, loops, faces).}*/ typedef typename SM_decorator::Sphere_kernel Sphere_kernel; /*{\Mtypemember the sphere kernel.}*/ typedef typename Sphere_kernel::Sphere_point Sphere_point; /*{\Mtypemember points.}*/ typedef typename Sphere_kernel::Sphere_segment Sphere_segment; /*{\Mtypemember segments.}*/ typedef typename Sphere_kernel::Sphere_circle Sphere_circle; /*{\Mtypemember circles.}*/ typedef typename Sphere_kernel::Sphere_direction Sphere_direction; /*{\Mtypemember directions.}*/ /*{\Mtext Local types are handles, iterators and circulators of the following kind: |SVertex_const_handle|, |SVertex_const_iterator|, |SHalfedge_const_handle|, |SHalfedge_const_iterator|, |SHalfloop_const_handle|, |SHalfloop_const_iterator|, |SFace_const_handle|, |SFace_const_iterator|.}*/ typedef CGAL::Object_handle Object_handle; /*{\Mtypemember a generic handle to an object of the underlying plane map. The kind of the object |(vertex, halfedge,face)| can be determined and the object assigned by the three functions:\\ |bool assign(SVertex_const_handle& h, Object_handle o)|\\ |bool assign(SHalfedge_const_handle& h, Object_handle o)|\\ |bool assign(SFace_const_handle& h, Object_handle o)|\\ where each function returns |true| iff the assignment of |o| to |h| was valid.}*/ typedef typename Decorator_traits::SVertex_handle SVertex_handle; typedef typename Decorator_traits::SHalfedge_handle SHalfedge_handle; typedef typename Decorator_traits::SHalfloop_handle SHalfloop_handle; typedef typename Decorator_traits::SFace_handle SFace_handle; typedef typename Decorator_traits::SVertex_iterator SVertex_iterator; typedef typename Decorator_traits::SHalfedge_iterator SHalfedge_iterator; typedef typename Decorator_traits::SHalfloop_iterator SHalfloop_iterator; typedef typename Decorator_traits::SFace_iterator SFace_iterator; typedef typename Decorator_traits::SHalfedge_around_svertex_circulator SHalfedge_around_svertex_circulator; typedef typename Decorator_traits::SHalfedge_around_sface_circulator SHalfedge_around_sface_circulator; using Base::cyclic_adj_succ; using Base::is_isolated; using Base::first_out_edge; Sphere_segment segment(SHalfedge_handle e) const { return Sphere_segment(e->source()->point(), e->twin()->source()->point(), e->circle()); } Sphere_direction direction(SHalfedge_handle e) const { return Sphere_direction(e->circle()); } SHalfedge_handle out_wedge(SVertex_handle v, const Sphere_direction& d, bool& collinear) const /*{\Xop returns a halfedge |e| bounding a wedge in between two neighbored edges in the adjacency list of |v| which contains |d|. If |d| extends along a edge then |e| is this edge. If |d| extends into the interior of such a wedge then |e| is the first edge hit when |d| is rotated clockwise. \precond |v| is not isolated.}*/ { CGAL_NEF_TRACEN("out_wedge "<<PH(v)); CGAL_assertion(!is_isolated(v)); collinear=false; Sphere_point p = v->point(); SHalfedge_handle e_res = first_out_edge(v); Sphere_direction d_res = direction(e_res); SHalfedge_around_svertex_circulator el(e_res),ee(el); if(direction(el) == d) { collinear = true; CGAL_NEF_TRACEN(" determined "<<PH(el) << el->circle()); return el; } CGAL_For_all(el,ee) { if(direction(cyclic_adj_succ(el)) == d) { collinear = true; CGAL_NEF_TRACEN(" equal "<<PH(cyclic_adj_succ(el)) << cyclic_adj_succ(el)->circle()); return cyclic_adj_succ(el); } else { CGAL_NEF_TRACEN("strictly_ordered_ccw " << direction(el) << " ? " << d << " ? " << direction(cyclic_adj_succ(el))); // if ( strictly_ordered_ccw_at(p,d_res, direction(el), d) ) { if ( strictly_ordered_ccw_at(p,direction(el), d, direction(cyclic_adj_succ(el))) ) { CGAL_NEF_TRACEN("strictly_ordered_ccw " << direction(el) << " - " << d << " - " << direction(cyclic_adj_succ(el))); e_res = el; d_res = direction(e_res); break; } } } CGAL_NEF_TRACEN(" finally determined "<<PH(e_res) << e_res->circle()); return e_res; } /*{\Mcreation 3}*/ SM_point_locator() : Base() {} /*{\Moptions constref=yes}*/ SM_point_locator(Sphere_map* cp) : Base(cp) {} /*{\Mcreate constructs a point locator working on |P|.}*/ /*{\Moptions constref=no}*/ /*{\Moperations 2.5 0.5}*/ const Mark& mark(Object_handle h) const /*{\Mop returns the mark associated to the object |h|.}*/ { SVertex_handle v; SHalfedge_handle e; SHalfloop_handle l; SFace_handle f; if ( CGAL::assign(v,h) ) return v->mark(); if ( CGAL::assign(e,h) ) return e->mark(); if ( CGAL::assign(l,h) ) return l->mark(); CGAL_assertion_msg(CGAL::assign(f,h), "PM_point_locator::mark: Object_handle holds no object."); CGAL::assign(f,h); return f->mark(); } enum SOLUTION { is_vertex_, is_edge_, is_loop_ }; // enumeration for internal use Object_handle locate(const Sphere_point& p, bool skipVEL = false) /*{\Mop returns a generic handle |h| to an object (vertex, halfedge, face) of the underlying plane map |P| which contains the point |p = s.source()| in its relative interior. |s.target()| must be a point such that |s| intersects the $1$-skeleton of |P|.}*/ { CGAL_NEF_TRACEN("locate naivly "<< normalized(p)); SVertex_iterator v; SHalfedge_iterator e; if(!skipVEL) { CGAL_forall_svertices(v,*this) { if ( p == v->point() ) { CGAL_NEF_TRACEN( " on point"); return make_object(v); } } CGAL_forall_sedges(e,*this) { if ( segment(e).has_on(p) || (e->source() == e->twin()->source() && e->circle().has_on(p))) { CGAL_NEF_TRACEN( " on segment " << segment(e)); return make_object(e); } } if ( this->has_shalfloop() && this->shalfloop()->circle().has_on(p)) { CGAL_NEF_TRACEN( " on loop"); return make_object(SHalfloop_handle(this->shalfloop())); } } // now in face: if(this->number_of_sfaces() == 1) { CGAL_NEF_TRACEN(" on unique face"); SFace_handle f = this->sfaces_begin(); return make_object(f); } SVertex_handle v_res; SHalfedge_handle e_res; SHalfloop_handle l_res(this->shalfloop()); SOLUTION solution; CGAL_NEF_TRACEN(" on face..."); Sphere_segment s; // we shorten the segment iteratively if ( this->has_shalfloop() ) { Sphere_circle c(this->shalfloop()->circle(),p); // orthogonal through p s = Sphere_segment(p,intersection(c,this->shalfloop()->circle())); l_res = this->shalfloop()->circle().has_on_positive_side(p) ? this->shalfloop() : this->shalfloop()->twin(); solution = is_loop_; CGAL_NEF_TRACEN("has loop, initial ray "<<s); CGAL_NEF_TRACEN(l_res->circle()); } else { // has vertices ! CGAL_assertion( this->number_of_svertices()!=0 ); SVertex_iterator vi = this->svertices_begin(); if( p == vi->point().antipode()) { ++vi; CGAL_assertion( vi != this->svertices_end()); } CGAL_NEF_TRACEN("initial segment: "<<p<<","<<vi->point()); CGAL_assertion( p != vi->point().antipode()); s = Sphere_segment( p, vi->point()); v_res = vi; solution = is_vertex_; CGAL_NEF_TRACEN("has vertices, initial ray "<<s); } // s now initialized Sphere_direction dso(s.sphere_circle().opposite()); Unique_hash_map<SHalfedge_handle,bool> visited(false); CGAL_forall_svertices(v,*this) { Sphere_point vp = v->point(); if ( s.has_on(vp) ) { CGAL_NEF_TRACEN(" location via vertex at "<<vp); s = Sphere_segment(p,vp,s.sphere_circle()); // we shrink the segment if ( is_isolated(v) ) { CGAL_NEF_TRACEN("is_vertex_"); v_res = v; solution = is_vertex_; } else { // not isolated bool dummy; e_res = out_wedge(v,dso,dummy); SHalfedge_around_svertex_circulator el(e_res),ee(el); CGAL_For_all(el,ee) visited[el] = visited[el->twin()] = true; /* e_res is now the counterclockwise maximal halfedge out of v just before s */ if ( e_res->circle().has_on_negative_side(p) ) e_res = e_res->sprev(); // correction to make e_res visible from p solution = is_edge_; CGAL_NEF_TRACEN(" determined "<<PH(e_res)); } } } CGAL_forall_sedges(e,*this) { if ( visited[e] ) continue; Sphere_segment se = segment(e); Sphere_point p_res; if(e->source() == e->twin()->source()) { Sphere_point p_res = intersection(e->circle(), s.sphere_circle()); if(!s.has_in_relative_interior(p_res)) { p_res = p_res.antipode(); if(!s.has_in_relative_interior(p_res)) continue; } s = Sphere_segment(p,p_res,s.sphere_circle()); e_res = ( e->circle().has_on_positive_side(p) ? e : e->twin() ); visited[e] = visited[e->twin()] = true; solution = is_edge_; CGAL_NEF_TRACEN(" determined "<<PH(e_res)<<" "<< e_res->incident_sface()->mark()); } else if ( do_intersect_internally(se,s,p_res) ) { CGAL_NEF_TRACEN(" location via halfedge "<<se); s = Sphere_segment(p,p_res,s.sphere_circle()); e_res = ( e->circle().has_on_positive_side(p) ? e : e->twin() ); visited[e] = visited[e->twin()] = true; solution = is_edge_; CGAL_NEF_TRACEN(" determined "<<PH(e_res)<<" "<< e_res->incident_sface()->mark()); } } switch ( solution ) { case is_edge_: return make_object(SFace_handle(e_res->incident_sface())); case is_loop_: return make_object(SFace_handle(l_res->incident_sface())); case is_vertex_: return make_object(SFace_handle(v_res->incident_sface())); default: CGAL_error_msg("missing solution."); } return Object_handle(); // never reached! } #if 0 //THIS CODE DOES NOT SEEM TO BE USED template <typename Object_predicate> Object_handle ray_shoot(const Sphere_point& p, const Sphere_direction& d, const Object_predicate& M) const /*{\Mop returns an |Object_handle o| which can be converted to a |SVertex_handle|, |SHalfedge_handle|, |SFace_handle| |h| as described above. The object predicate |M| has to have function operators \\ |bool operator() (const SVertex_/SHalfedge_/SHalfloop_/SFace_handle&)|.\\ The object returned is intersected by |d.circle()|, has minimal distance to |p|, and |M(h)| holds on the converted object. The operation returns the null handle |NULL| if the ray shoot along |s| does not hit any object |h| of |M| with |M(h)|.}*/ { Sphere_circle c(d.circle()); Sphere_segment s; Object_handle h = locate(p); SVertex_handle v; SHalfedge_handle e; SHalfloop_handle l; SFace_handle f; if ( ( CGAL::assign(v,h) && M(v) ) || ( CGAL::assign(e,h) && M(e) ) || ( CGAL::assign(l,h) && M(l) ) || ( CGAL::assign(f,h) && M(f) ) ) return h; h = Object_handle(); CGAL_NEF_TRACEN("not contained"); #if 0 HASEN: s am anfang circle, ab wann segment ? wo loop ? bool s_init(false); CGAL_forall_svertices (v,*this) { Point pv = v->point(); if ( !(s_init && s.has_on(pv) || !s_init && c.has_on(pv)) ) continue; CGAL_NEF_TRACEN("candidate "<<pv); if ( M(v) ) { h = make_object(v); // store vertex s = Sphere_segment(p,pv,c); // shorten continue; } // now we know that v is not marked but on s bool collinear; SHalfedge_handle e = out_wedge(v,d,collinear); if ( collinear ) { if ( M(e) ) { h = make_object(e); s = Sphere_segment(p,pv,c); } continue; } if ( M(e->incident_sface()) ) { h = make_object(e->incident_sface()); s = Sphere_segment(p,pv,c); } } // all vertices CGAL::Unique_hash_map<SHalfedge_handle,bool> visited(false); SHalfedge_iterator e_res; CGAL_forall_sedges(e,*this) { Sphere_segment se = segment(e); Sphere_point p_res; if ( do_intersect_internally(se,s,p_res) ) { // internal intersection CGAL_NEF_TRACEN("candidate "<<se); e_res = e; Sphere_segment s_cand = Sphere_segment(p,p_res,c); if ( s_cand.is_short() && e->circle().has_on_negative_side(p) || s_cand.is_long() && e->circle().has_on_positive_side(p) || s_cand.is_halfcircle() && strictly_ordered_ccw_at(p.antipode(), direction(e),d,direction(e->twin())) ) e_res = e->twin(); if ( M(e_res) ) { h = make_object(e_res); s = s_cand; } else if ( M(face(twin(e_res))) ) { h = make_object(face(twin(e_res))); s = s_cand; } } } #endif CGAL_error_msg("not yet correct"); return h; } #endif Object_handle ray_shoot(const Sphere_point& p, const Sphere_circle& c, Sphere_point& ip, bool start_inclusive = false) { Sphere_segment seg(p, p.antipode(), c); return ray_shoot(seg, ip, start_inclusive); } Object_handle ray_shoot(const Sphere_segment& d, Sphere_point& ip, bool start_inclusive = false, bool beyond_end = true, bool end_inclusive = false) { // TODO: end_inclusive=true does not work properly for sedges and sloops CGAL_NEF_TRACEN("ray shoot"); Sphere_circle c(d.sphere_circle()); Sphere_point p(d.source()); Sphere_segment s; bool s_init(false); if(!beyond_end) { s = d; s_init = true; } Object_handle h = Object_handle(); if(s_init) { CGAL_NEF_TRACEN(" at begin " << s_init << ":" << s); } else { CGAL_NEF_TRACEN(" at begin " << s_init << ":" << c); } SVertex_iterator vi; CGAL_forall_svertices (vi,*this) { Sphere_point pv = vi->point(); if ((s_init && !s.has_on(pv)) || (!s_init && !c.has_on(pv))) continue; CGAL_NEF_TRACEN("candidate "<<pv); CGAL_NEF_TRACEN("p =?= pv: " << p << ", " << pv); if ((start_inclusive || p != pv) && (end_inclusive || !s_init || s.target() != pv)) { h = make_object(vi); // store vertex s = Sphere_segment(p,pv,c); // shorten ip = pv; s_init = true; } } // TODO: edges on the ray. SHalfedge_iterator ei; CGAL_forall_sedges(ei,*this) { Sphere_segment se = segment(ei); CGAL_NEF_TRACEN("ray_shoot " << s_init); if(s_init) { CGAL_NEF_TRACEN(" " << s.source() << "->" << s.target() << " | " << s.sphere_circle() << " is long " << s.is_long()); } CGAL_NEF_TRACEN(" " << se.source() << "->" << se.target() << " | " << se.sphere_circle() << " is long " << se.is_long()); // TODO: start-end point of s on se or c Sphere_point p_res; if(se.source() == se.target()) { if(s_init) { if(s.is_long()) { Sphere_segment first_half(p,p.antipode(),c); Sphere_segment second_part(p.antipode(), s.target(), c); if(!do_intersect_internally(ei->circle(), first_half, p_res) && !do_intersect_internally(ei->circle(), second_part, p_res)) { if(se.has_on(p.antipode())) { p_res = p.antipode(); } else { continue; } } } else { if(!do_intersect_internally(ei->circle(), s, p_res)) continue; } } else { Sphere_segment first_half(p,p.antipode(),c); Sphere_segment second_part(p.antipode(),p,c); if(!do_intersect_internally(ei->circle(), first_half, p_res)) { do_intersect_internally(ei->circle(), second_part, p_res); } } } else { if(s_init) { if(s.is_long() && se.is_long()) { Sphere_segment first_half(p,p.antipode(),c); Sphere_segment second_part(p.antipode(), s.target(), c); if(!do_intersect_internally(se, first_half, p_res) && !do_intersect_internally(se, second_part, p_res)) { if(se.has_on(p.antipode())) p_res = p.antipode(); else continue; } } else { if(!do_intersect_internally(se, s, p_res)) continue; } } else { if(se.is_long()) { Sphere_segment first_half(p,p.antipode(),c); Sphere_segment second_half(p.antipode(),p,c); if(!do_intersect_internally(se, first_half, p_res)) { if(!do_intersect_internally(se, second_half, p_res)) { if(start_inclusive) p_res = p; else p_res = p.antipode(); } } } else { if(!do_intersect_internally(c, se, p_res)) continue; } } } CGAL_NEF_TRACEN("candidate "<<se); if (start_inclusive || p != p_res) { h = make_object(ei); s = Sphere_segment(p,p_res,c); ip = p_res; s_init = true; } } // TODO: start-end point of s on cl if(this->has_shalfloop()) { Sphere_circle cl(this->shalfloop()->circle()); if(!s_init || s.is_long()) { if(cl.has_on(p)) { ip = p.antipode(); return make_object(SHalfloop_handle(this->shalfloop())); } else s = Sphere_segment(p,p.antipode(),c); } Sphere_point p_res; CGAL_NEF_TRACEN("do intersect " << cl << ", " << s); if(!do_intersect_internally(cl,s,p_res)) return h; /* if(p_res == p.antipode()) // does this happen ? test has_on for p/p.antipode ? p_res = p; */ CGAL_NEF_TRACEN("found intersection point " << p_res); CGAL_assertion_code(Sphere_segment testseg(p,p_res,c)); CGAL_assertion(!testseg.is_long()); if (start_inclusive || p != p_res) { ip = p_res; return make_object(SHalfloop_handle(this->shalfloop())); } } return h; } void marks_of_halfspheres(std::vector<Mark>& mohs, int offset, int axis=2); void marks_of_halfspheres(Mark& unten, Mark& oben, int axis=2); /*{\Mimplementation Naive query operations are realized by checking the intersection points of the $1$-skeleton of the plane map |P| with the query segments $s$. This method takes time linear in the size $n$ of the underlying plane map without any preprocessing.}*/ }; // SM_point_locator<SM_decorator> template <typename D> void SM_point_locator<D>:: marks_of_halfspheres(std::vector<Mark>& mohs, int offset, int axis) { Mark lower, upper; marks_of_halfspheres(lower, upper, axis); mohs[offset] = lower; mohs[offset+1] = upper; } template <typename D> void SM_point_locator<D>:: marks_of_halfspheres(Mark& lower, Mark& upper, int axis) { CGAL_NEF_TRACEN("marks_of_halfspheres "); Sphere_point y_minus; if(axis!=1) y_minus = Sphere_point(0,-1,0); else y_minus = Sphere_point(0,0,1); Object_handle h = locate(y_minus); SFace_handle f; if ( CGAL::assign(f,h) ) { CGAL_NEF_TRACEN("on face " << mark(make_object(f))); lower = upper = mark(make_object(f)); return; } SHalfedge_handle e; if ( CGAL::assign(e,h) ) { CGAL_assertion(e->circle().has_on(y_minus)); Sphere_point op(CGAL::ORIGIN+e->circle().orthogonal_vector()); CGAL_NEF_TRACEN("on edge "<<op); if (axis==0 && ((op.z() < 0) || ((op.z() == 0) && (op.x() < 0)))) e = e->twin(); if (axis==1 && ((op.x() > 0) || ((op.x() == 0) && (op.y() < 0)))) e = e->twin(); if (axis==2 && ((op.x() > 0) || ((op.x() == 0) && (op.z() < 0)))) e = e->twin(); upper = e->incident_sface()->mark(); lower = e->twin()->incident_sface()->mark(); return; } SHalfloop_handle l; if ( CGAL::assign(l,h) ) { CGAL_assertion(l->circle().has_on(y_minus)); Sphere_point op(CGAL::ORIGIN+l->circle().orthogonal_vector()); CGAL_NEF_TRACEN("on loop "<<op); if (axis==0 && ((op.z() < 0) || ((op.z() == 0) && (op.x() < 0)))) l = l->twin(); if (axis==1 && ((op.x() > 0) || ((op.x() == 0) && (op.y() < 0)))) l = l->twin(); if (axis==2 && ((op.x() > 0) || ((op.x() == 0) && (op.z() < 0)))) l = l->twin(); upper = l->incident_sface()->mark(); lower = l->twin()->incident_sface()->mark(); return; } Sphere_circle c; switch(axis) { case 0: c = Sphere_circle(1,0,0); break; case 1: c = Sphere_circle(0,1,0); break; case 2: c = Sphere_circle(0,0,1); break; } Sphere_direction right(c),left(c.opposite()); bool collinear(false); SVertex_handle v; if ( CGAL::assign(v,h) ) { CGAL_assertion(v->point()==y_minus); if(is_isolated(v)) upper = lower = mark(make_object(v->incident_sface())); else { e = out_wedge(v,left,collinear); if ( collinear ) upper = e->twin()->incident_sface()->mark(); else upper = e->incident_sface()->mark(); e = out_wedge(v,right,collinear); if ( collinear ) lower = e->twin()->incident_sface()->mark(); else lower = e->incident_sface()->mark(); } } } } //namespace CGAL #endif // CGAL_SM_POINT_LOCATOR_H
- [cgal-discuss] "wrong handle" error when running convex_decomposition_3, Nicholas Mario Wardhana, 06/24/2011
- Re: [cgal-discuss] "wrong handle" error when running convex_decomposition_3, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] "wrong handle" error when running convex_decomposition_3, Nicholas Mario Wardhana, 06/27/2011
