Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
- To:
- Subject: Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
- Date: Mon, 27 Jun 2011 10:18:20 +0200
For a facet incident to two finite cells,
the dual is a segment joigning the (weighted) circumcenters)
of incident cells. In degenerate situations, it may happen
that both circumcenters are located on the same point.
Le 27/06/11 09:09, Sebastien Loriot (GeometryFactory) a écrit :
How did you check that the source and target of the segment
are equal?
If you checked it with an assertion in the code, then we probably need
to get a minimal example showing the problem to provide you a fix.
Sebastien.
randooom wrote:
tl;dr: see subject line
Following a little explanation what I try to accomplish and why.
I have a Regular_triangulation_3 rt and want to extract the power diagram
cell by cell (and only the finite ones).
My algorithm is basically as follows:
CellContainer cells
foreach finite_vertex fv in rt:
foreach incident_cell ic to fv:
check if ic is infinite.
if no_infinite_incident_cell_found
MyCell mc foreach incident_vertex iv of fv:
MyFacet mf
get edge e with rt.is_edge(fv, iv, ...)
circulate over incident_facets if of e:
Segment_3 s = (Object cast and so forth) rt.dual(if) // [1] mf.addEdge(s)
mc.addFacet(mf)
cells.addCell(mc)
[1] at this point I sometimes get a Segment_3 s with identical s.source()
and s.target(). How can this be, and what can I do about it? This makes
really no sense to me... :)
Thank you for you time reading this and I hope someone can help me; any tips
and suggestions are much appreciated!
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Why-does-Regular-triangulation-3-dual-Facet-f-sometimes-return-a-edge-with-identical-source-and-targ-tp3625888p3625888.html
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, randooom, 06/26/2011
- [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, randooom, 06/26/2011
- Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Mariette Yvinec, 06/27/2011
- [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, randooom, 06/27/2011
- Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Mariette Yvinec, 06/27/2011
- Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Monique Teillaud, 06/27/2011
