- To:
- Subject: Re: [cgal-discuss] Re: compilation error: new project from scratch
- Date: Mon, 27 Jun 2011 18:24:02 +0200
On lundi 27 juin 2011 18:08:41 vanimurarka wrote:
> Hi,
> I managed to remove the errors being generated from moc_Viewer.obj by
> including QGLViewerd2.lib and psapi.lib in the Linker->Input->Additional
> Dependencies setting in my VS project settings. I cannot see how to remove
> the following error that remains:
> Error 1 error LNK2019: unresolved external symbol "public: __thiscall
> Viewer::Viewer(class QWidget *,bool)"
> (??0Viewer@@QAE@PAVQWidget@@_N@Z)
> referenced in function "public: void __thiscall
> Ui_qttrialClass::setupUi(class QMainWindow *)"
> (?setupUi@Ui_qttrialClass@@QAEXPAVQMainWindow@@@Z)
> qttrial.obj
You should include Viewer.cpp in your project. That is probably in that file
that the constructor of Viewer is defined.
Laurent Rineau, PhD
- [cgal-discuss] compilation error: new project from scratch, vanimurarka, 06/25/2011
- [cgal-discuss] Re: compilation error: new project from scratch, vanimurarka, 06/27/2011
- Re: [cgal-discuss] Re: compilation error: new project from scratch, Laurent Rineau (GeometryFactory), 06/27/2011
