- To:
- Subject: Re: [cgal-discuss] Problems joining Nef_Polyhedron
- Date: Wed, 06 Jul 2011 08:07:36 +0200
Benjamin McWhorter wrote:
Hello,
I am having the following problem when joining together two simple and valid
Nef Polyhedron. I was hoping somebody could help me understand why the
resulting Nef is not simple. I have attached the original .obj files and the
.OFF files.
After the join, the resulting Nef is not simple. If I try to convert that
Nef to a polyhedron, I get this error:
The intersection of your models is a segment. The result of the union is
is two volumes joint by an edge, which makes it not simple.
Sebastien.
CGAL::Polyhedron_incremental_builder_3<HDS>::
lookup_hole(): input error: at vertex 1 a closed surface already exists and
facet 14 is nonetheless adjacent.
The closed cycle of facets is: 5 1 2.
I am sorry if this is a simple question, but I have not been able to come to
any conclusions.
Thanks,
Ben.
- [cgal-discuss] Problems joining Nef_Polyhedron, Benjamin McWhorter, 07/05/2011
- Re: [cgal-discuss] Problems joining Nef_Polyhedron, Sebastien Loriot (GeometryFactory), 07/06/2011
