cgal-discuss - [cgal-discuss] CGAL 3.4 install with VC9 [win7]
  • To:
  • Subject: [cgal-discuss] CGAL 3.4 install with VC9 [win7]
  • Date: Wed, 6 Jul 2011 22:49:46 +0200
 I attempted to install CGAL 3.4 on a clean pc (also running windows7 and vc9). Sadly, I reproduced this problem
CGAL_MAJOR_VERSION=3
CGAL_MINOR_VERSION=4
CGAL_BUILD_VERSION=
CGAL_SONAME_VERSION=3
CGAL_SOVERSION =3.0.0
CGAL_REFERENCE_CACHE_DIR=
Building static libraries
CMake Warning (dev) at CMakeLists.txt:88 (include):
Policy CMP0011 is not set: Included scripts do automatic cmake_policy PUSH
and POP. Run "cmake --help-policy CMP0011" for policy details. Use the
cmake_policy command to set the policy and suppress this warning.
The included script
C:/CGAL-3.4/cmake/modules/CGAL_Common.cmake
affects policy settings. CMake is implying the NO_POLICY_SCOPE option for
compatibility, so the effects are applied to the including context.
This warning is for project developers. Use -Wno-dev to suppress it.
Targetting Visual Studio 9 2008
Target build enviroment supports auto-linking
Using VC90 compiler.
Generator uses intermediate configuration directory: $(OutDir)
USING CMake version: 2.8.4
System: Windows
Build type: Release
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /MD /O2 /Ob2 /D NDEBUG -D_SECURE_SCL=0'
USING LDFLAGS = ' '
GMP include: C:/CGAL-3.4/auxiliary/gmp/include
GMP libraries:
GMP definitions:
USING GMP_VERSION = '4.2.4'
MPFR include: C:/CGAL-3.4/auxiliary/gmp/include
MPFR libraries:
MPFR definitions:
USING MPFR_VERSION = '2.3.2'
CMake Error at cmake/modules/FindBoost.cmake:613 (message):
Unable to find the requested Boost libraries.
Unable to find the Boost header files. Please set BOOST_ROOT to the root
directory containing Boost or BOOST_INCLUDEDIR to the directory containing
Boost's headers.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:12 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:17 (include)
CMakeLists.txt:201 (include)
Boost include: Boost_INCLUDE_DIR-NOTFOUND
Boost libraries:
Boost definitions:
USING BOOST_VERSION = '..'
CMAKE_INSTALL_PREFIX=C:/Program Files/CGAL
CMake Warning (dev) at C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:85 (INCLUDE):
File C:/Program Files/CMake
2.8/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake includes
C:/CGAL-3.4/cmake/modules/FindPackageMessage.cmake (found via
CMAKE_MODULE_PATH) which shadows C:/Program Files/CMake
2.8/share/cmake-2.8/Modules/FindPackageMessage.cmake. This may cause
errors later on .
Policy CMP0017 is not set: Prefer files from the CMake module directory
when including from there. Run "cmake --help-policy CMP0017" for policy
details. Use the cmake_policy command to set the policy and suppress this
warning.
C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/FindZLIB.cmake:69 (INCLUDE)
src/CGALimageIO/CMakeLists.txt:16 (find_package)
Could NOT find ZLIB (missing: ZLIB_INCLUDE_DIR ZLIB_LIBRARY)
OpenGL include:
OpenGL libraries: glu32;opengl32
NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature will not be activated.
CGAL_Qt3 needs Qt3, cannot be configured.
CGAL_Qt4 needs Qt4, cannot be configured.
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
Boost_INCLUDE_DIR (ADVANCED)
used as include directory in directory C:/CGAL-3.4/src/CGAL
used as include directory in directory C:/CGAL-3.4/src/CGALCore
used as include directory in directory C:/CGAL-3.4/src/CGALimageIO
used as include directory in directory C:/CGAL-3.4/src/CGALPDB
used as include directory in directory C:/CGAL-3.4/src/CGALQt
used as include directory in directory C:/CGAL-3.4/src/CGALQt4
Configuring incomplete, errors occurred!
help me to fix this problem
Randa Amich
Élève ingénieur en 3eme année informatique
École Nationale des Sciences de l'Informatique
Master de  Recherche Informatique
Tel:(+216) 20 67 04 71
Mail :
