cgal-discuss - [cgal-discuss] calculate intersection with an infinite facet
  • To:
  • Subject: [cgal-discuss] calculate intersection with an infinite facet
  • Date: Fri, 8 Jul 2011 16:24:13 +0200
  • Importance: Normal
Hi,
I meshed a sphere and I considered a set of lines crossing each mesh
vertex. Then I calculate the intersections (CGAL::intersections) of these
lines with the triangles opposite to the vertex under study and belonging
to the cells incident to the vertex
(c3t3.triangulation().incident_cells(vit,std::back_inserter(incident_cells))).
When calculating the intersection with a triangle of an infinite cell
(that is the vertex is on the convex hull) I notice that two triangle
vertexes are on the sphere surface and one gives me "vertex coordinates:
0 0 0, squared distance from the sphere center 0". I guess this is because
this is the infinite vertex.
My question is: how the intersection is evaluated in this case? (in the
manual I see "Notice that the infinite vertex has no significant
coordinates and that no geometric predicate can be applied on it.")
I find, indeed, that for each direction two (or 0) intersections are
recovered at the end of each loop on the incident cells. I mean also the
intersection with the opposite facet on the infinite incident cell seems
to be detected. Nevertheless, also for the infinite incident cell, the
intersection point is in the interior of the sphere although it belongs to
the triangle which has two vertexes on the sphere surface, and the third
is the infinite vertex (the fourth vertex of the cell is the vertex of
interest and it is on the convex hull).
Thank you in advance
