- To:
- Subject: Re: [cgal-discuss] surface-parametrization
- Date: Fri, 8 Jul 2011 00:53:16 +0200
i opened the command prompt (i.e. start->run "cmd.exe") i get a black window with
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\i run this command but i have this problem " D:\Surface_mesh_parameterization -h n'est pas reconnu en tant que commande interne "
how can i fix this pb
2011/7/7 Giles Bathgate <>
You managed to compile the example using cmake? so you must have opened up a command prompt (i.e. start->run "cmd.exe") and then get a black window with:Microsoft Windows [Version 6.1.7600]Copyright (c) Microsoft Corporation. All rights reserved.C:\All Sebastien is telling you to do is at the C:\ type out C:\CGAL\polyhedron_ex_parameterization -hso you just type " -h" at the end and it will print out some help text
Does that make things any clearer?RegardsOn 7 July 2011 18:06, amich randa <> wrote:first i don't understand how i use 'Surface_mesh_parameterization example ' after i compile it with c-makesorry but this is the first that i will use cgal
and i don't know how i can use the file .off to have the paramatrization method ?
Randa Amich
Élève ingénieur en 3eme année informatique
École Nationale des Sciences de l'Informatique
Master de Recherche Informatique
Tel:(+216) 20 67 04 71
Mail :
- Re: [cgal-discuss] surface-parametrization, (continued)
- Re: [cgal-discuss] surface-parametrization, amich randa, 07/07/2011
- Re: [cgal-discuss] surface-parametrization, Sebastien Loriot (GeometryFactory), 07/07/2011
- Re: [cgal-discuss] surface-parametrization, Giles Bathgate, 07/07/2011
- Re: [cgal-discuss] surface-parametrization, amich randa, 07/08/2011
