cgal-discuss - Re: [cgal-discuss] Lindstrom-Turk with texture coords problem
  • To:
  • Subject: Re: [cgal-discuss] Lindstrom-Turk with texture coords problem
  • Date: Mon, 11 Jul 2011 09:13:41 +0200
The possible new position of vertex is computed using a functor that
is a model of the concept GetPlacement.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesh_simplification_ref/FunctionObjectConcept_GetPlacement.html
In particular, you can get the information about the collapsed edge
using a model of the EdgeProfile concept:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesh_simplification_ref/Concept_EdgeProfile.html
This neighborhood should allow you to update your texture information.
Look at the models provided by CGAL to see how you can provide you own
models fitting your needs.
Sebastien.
JWANG wrote:
hi,all
I have use Lindstrom-Turk edge-collapse algorithm for mesh
simplification.but I had some trouble.
In my case,i construct polyhedron through delaunay triangles with texture
coords,then use Lindstrom-Turk algorithm for simplification.
How can i get the new texture coords with Get_Placement polices? or what
esle i can do to calculate texture coords.
thanks!
WANG
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Lindstrom-Turk-with-texture-coords-problem-tp3631838p3631838.html
  • Re: [cgal-discuss] Lindstrom-Turk with texture coords problem, Sebastien Loriot (GeometryFactory), 07/11/2011
