cgal-discuss - Re: [cgal-discuss] surface of a polyhedron embedded on the sphere
  • To:
  • Subject: Re: [cgal-discuss] surface of a polyhedron embedded on the sphere
  • Date: Mon, 11 Jul 2011 11:43:35 +0200
Francois Berenger wrote:
On 07/11/2011 03:58 PM, Sebastien Loriot (GeometryFactory) wrote:
Your question is not clear to me. Can you elaborate?
Hello,
1) I would like to know if it is possible to compute the surface
of a Nef polyhedra (I guess yes).
I don't need the exact procedure in fact, but for sure it would
educate me even if some CGAL expert just gives a rough idea.
This code is used to compute the Nef_3 boolean operations for example,
so it is working. I never try to use it with an inexact construction
kernel so I have no idea whether you could use it with such a kernel
(this is not possible for Nef_3 for example)
2) I'd like to have an idea of the complexity of the procedure
(O(n**something)?) to assess if it is worth doing with CGAL
or if an approximation of it would be faster.
This is computing an arrangement of great circle arcs on a sphere.
If I remember correctly, it is using two sweep algorithms, so the theoretical complexity should be something like O( (n+k)log(n) ) n being
the number of input and k the number of intersection points.
Note that there exists an experimental implementation using the CGAL
2D arrangement package doing something similar.
See this paper for example:
http://www.cs.tau.ac.il/~efif/publications/sphere_vor/sphere_vor.pdf
Sebastien.
Regards,
F.
Sebastien.
Hello,
Is it possible to compute the surface
of the selected region as can be seen in
the right hand part of figure Figure 21.1 from
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_S2/Chapter_main.html
Let's say we have N triangles on the sphere, would it be
computationally intensive?
Regards,
F.
