- To:
- Subject: Re: [cgal-discuss] generating mesh from alpha shape
- Date: Tue, 19 Jul 2011 13:24:07 +0200
Regular facets form the boundary of the alpha_shapes.
If you are lucky, they may form a manifold surface mesh
but this is not granted.
Le 19/07/11 12:20, Farhad Bazyari a écrit :
Hi guys,
Sorry for novice question!
I have a point cloud from which I can make fixed alpha shape. Now I want to get the
"exterior" of that alpha shape as a mesh. is there an example in the manual
about it? cause I couldn't find anything. I think it should be REGULAR facets of the
alpha shape.
figure 47.2 (chapter 47!) suggests that I can get orientation for points, I
couldn't figure out how exactly I can do that either. (I was thinking of
making mesh out of REGULAR points with known normals)
Thanks in advance for your help,
Farhad
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- [cgal-discuss] CGAL polygon intersection predicate - precondition exception!, Gillian Ng, 07/19/2011
- Re: [cgal-discuss] CGAL polygon intersection predicate - precondition exception!, Gernot H. Gutschi, 07/19/2011
- Re: [cgal-discuss] CGAL polygon intersection predicate - precondition exception!, ravi teja, 07/19/2011
- [cgal-discuss] generating mesh from alpha shape, Farhad Bazyari, 07/19/2011
- Re: [cgal-discuss] generating mesh from alpha shape, Mariette Yvinec, 07/19/2011
- [cgal-discuss] Re: CGAL polygon intersection predicate - precondition exception!, Gillian Ng, 07/20/2011
- Re: [cgal-discuss] Re: CGAL polygon intersection predicate - precondition exception!, Sebastien Loriot (GeometryFactory), 07/20/2011
- [cgal-discuss] Re: CGAL polygon intersection predicate - precondition exception!, Gillian Ng, 07/21/2011
