Re: [cgal-discuss] Re: CGAL polygon intersection predicate - precondition exception!
- To:
- Subject: Re: [cgal-discuss] Re: CGAL polygon intersection predicate - precondition exception!
- Date: Wed, 20 Jul 2011 23:05:40 +0200
Note that even if do_intersect is a predicates, this is not a predicate
from the kernel and the exact_predicates_inexact_constructions_kernel
is not sufficient.
The documentation is here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Boolean_set_operations_2_ref/Function_do_intersect.html#Cross_link_anchor_1015
There is nothing that allow you to convert a polygon of kernel
to another.
Cartesian_converter only works for objects that are in the kernel
(that is points for example, see here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Class_Cartesian_converter.html
Anyway, it would not be efficient at all since you will have to convert
all the points each time you want to make an intersection test.
The best solution would be to make this predicate safe with an
an exact predicates only kernel.
I will have a look at it.
In the meantime, could you provide the example polygon that lead to the
assertion.
Sebastien.
On 07/20/2011 03:38 AM, Gillian Ng wrote:
Oh, I didn't know it required an exact constructions kernel. It works
perfectly now, thanks a lot!
By the way, is there any way to convert kernel types easily? My code has
been using exact_predicates_inexact_constructions, but when I switched it to
using exact_predicates_exact_constructions, it gave a ridiculous amount of
errors. Is this even normal? I ended up storing two Polygons, one with exact
constructions and one with inexact constructions, pretty clunky...
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-polygon-intersection-predicate-precondition-exception-tp3677725p3679799.html
- [cgal-discuss] CGAL polygon intersection predicate - precondition exception!, Gillian Ng, 07/19/2011
- Re: [cgal-discuss] CGAL polygon intersection predicate - precondition exception!, Gernot H. Gutschi, 07/19/2011
- Re: [cgal-discuss] CGAL polygon intersection predicate - precondition exception!, ravi teja, 07/19/2011
- [cgal-discuss] generating mesh from alpha shape, Farhad Bazyari, 07/19/2011
- Re: [cgal-discuss] generating mesh from alpha shape, Mariette Yvinec, 07/19/2011
- [cgal-discuss] Re: CGAL polygon intersection predicate - precondition exception!, Gillian Ng, 07/20/2011
- Re: [cgal-discuss] Re: CGAL polygon intersection predicate - precondition exception!, Sebastien Loriot (GeometryFactory), 07/20/2011
- [cgal-discuss] Re: CGAL polygon intersection predicate - precondition exception!, Gillian Ng, 07/21/2011
