- To:
- Subject: Re: [cgal-discuss] nef_polyhedra work with CORE::Expr in release but not debug
- Date: Mon, 01 Aug 2011 12:15:43 -0700
Thank you. Why does this compile in Release mode though?
Cody
On 8/1/2011 6:05 AM, Michael Hemmer wrote:
The problem is that the function
template<typename R> static
CGAL::Plane_3<R> normalized(const CGAL::Plane_3<R>& h) {
in file Nef_S2/Normalizing.h
assumes that FT is decomposable into a numerator and a denominator.
This is not the case if FT is CORE::Expr.
The function should first check whether it can decompose FT using the
tag that is provided by the Fraction_traits.
If FT is not decomposable it is probably best to divide all
coefficients by the first coefficient that is not zero.
This way one also achieves a normalized, i.e. unique representation,
of the plane.
Michael Hemmer
On Mon, Aug 1, 2011 at 1:20 AM, Cody
Rose<>
wrote:
In Visual Studio 2010, the code:
#include "CGAL/CORE_Expr.h"
#include "CGAL/Cartesian.h"
#include "CGAL/Nef_polyhedron_3.h"
typedef CGAL::Cartesian<CORE::Expr> K;
typedef CGAL::Nef_polyhedron_3<K> nef;
int main() {
nef foo;
compiles in Release mode but not Debug mode. The error is
cgal\nef_s2\normalizing.h(307): error C2676: binary '*=' : 'CGAL::Null_tag'
does not define this operator or a conversion to a type acceptable to the
predefined operator
many times. Someone else on this mailing list had this problem back in 2008,
but that was resolved by switching kernels. However, I need square roots,
and therefore (as I understand it) the only number types I can use are
CORE::Expr and leda_real. I'm getting vastly better performance with
CORE::Expr so I would really like to avoid leda_real. The fact that this
works fine in Release mode indicates to me that there must be some way to
get it to work in Debug mode, but the earlier thread didn't discuss why that
might be.
Thanks,
Cody
- [cgal-discuss] nef_polyhedra work with CORE::Expr in release but not debug, Cody Rose, 08/01/2011
- Re: [cgal-discuss] nef_polyhedra work with CORE::Expr in release but not debug, Michael Hemmer, 08/01/2011
- Re: [cgal-discuss] nef_polyhedra work with CORE::Expr in release but not debug, Cody Rose, 08/01/2011
- Re: [cgal-discuss] nef_polyhedra work with CORE::Expr in release but not debug, Michael Hemmer, 08/02/2011
