cgal-discuss - Re: [cgal-discuss] intersections on mesh boundary
  • To:
  • Subject: Re: [cgal-discuss] intersections on mesh boundary
  • Date: Mon, 01 Aug 2011 18:43:59 +0200
When the line goes through a vertex a the convex hull
you can get
1 when the line is within the cone formed by the triangles
of the convex hull incident to the vertex
and 0 otherwise.
For the direction and the cube you choose,
its seems that you can get 0 for any vertex on
(or close to)
one of the edges
of the cube.
Le 01/08/11 14:03,
a écrit :
Hi,
I mesh a cube. Then I consider a line crossing each mesh vertex and I look
for the intersections between the line and the triangle of each incident
cell opposite to the vertex. At the end of each iteration on the incident
cells I expect one intersection (with a finite cell) if one of the
intersected cells is on the convex hull (vertex on boundary), two
intersection if both the intersected cells are finite (vertex in the
volume). Otherwise I found also the case of intersection number=0. For the
case of finite cells incident to the vertex I guess this is due to the
convexity of the small neighborhood of the vertex and it should occur only
for the direction tangent to the meshed object . This is not the case in
the minimal example I attach. (When both finite and infinite incident
cells are considered this
should corresponds to have two intersections with infinite cells.) I
verify that intersection number=0 occurs only for vertexes incident to the
infinite vertex.
Am I experiencing an accuracy problem on the boundary? The result doesn't
change refining the facet parameters.
Thanks in advance for any suggestion
#include<CGAL/Exact_predicates_inexact_constructions_kernel.h>
#include<CGAL/Exact_predicates_exact_constructions_kernel.h>
#include<CGAL/Cartesian_converter.h>
#include<CGAL/Mesh_triangulation_3.h>
#include<CGAL/Mesh_complex_3_in_triangulation_3.h>
#include<CGAL/Mesh_criteria_3.h>
#include<CGAL/Implicit_mesh_domain_3.h>
#include<CGAL/make_mesh_3.h>
#include<CGAL/intersections.h>
// Domain
struct K: public CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef K::FT FT;
typedef K::Point_3 Point;
typedef FT (Function)(const Point&);
typedef CGAL::Implicit_mesh_domain_3<Function,K> Mesh_domain;
// Triangulation/domain
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
// Triangulation
typedef C3t3::Triangulation Tr;
typedef C3t3::Cell_handle Cell_handle;
typedef Tr::Finite_vertices_iterator Finite_vertices_iterator;
typedef Tr::Vertex_handle Vertex_handle;
//new kernel:exact constructions
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Cartesian_converter<K,Kernel> converter_exact;
typedef CGAL::Cartesian_converter<Kernel,K> converter_inexact;
//Geometric objects for both the kernels
typedef K::Segment_3 Segment;
typedef K::Triangle_3 Triangle;
typedef Kernel::Direction_3 Direction;
typedef Kernel::Line_3 Lineconv;
typedef Kernel::Point_3 Pointex;
typedef Kernel::Triangle_3 Triangleconv;
typedef Kernel::Segment_3 Segmentconv;
// To avoid verbose function and named parameters call
using namespace CGAL::parameters;
// Function
FT cube_function (const Point& p){
if( (p.x())< 1&& -(p.x())< 1&&
(p.y())< 1&& -(p.y())< 1&&
(p.z())< 1&& -(p.z())< 1 )
return -1.;
return 1.;
int main()
// Domain
Mesh_domain domain(cube_function, K::Sphere_3(CGAL::ORIGIN, 2.));
// Criteria
Mesh_criteria criteria(facet_angle=30, facet_size=0.3, facet_distance=0.1,
cell_radius_edge=2, cell_size=0.3);
// Mesh generation and optimization
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria,
lloyd(time_limit=30),
no_perturb(),
exude(time_limit=30, sliver_bound=10));
//converter to_exact to evaluate intersection points;
converter_exact to_exact;
converter_inexact to_inexact;
Point picos(0.2,0.5,0.1);
Point porig(0.0,0.0,0.0);
Pointex picos_ex=to_exact(picos);
Pointex porig_ex=to_exact(porig);
Segmentconv seg(porig_ex,picos_ex);
Direction dir(seg.direction());
int count_vert=0;
for(Finite_vertices_iterator vit =
c3t3.triangulation().finite_vertices_begin();
vit != c3t3.triangulation().finite_vertices_end();
++vit)
std::cout<<"SCAN VERTEX"<<++count_vert<<"th
vertex"<<std::endl;
Point vertexpoint = vit->point();
Pointex vertexpoint_ex=to_exact(vertexpoint);
Lineconv line_vertex(vertexpoint_ex,dir);
std::vector<Cell_handle> incident_cells;
bool is_on_chull=false;
int nb_inter=0;
c3t3.triangulation().incident_cells(vit,std::back_inserter(incident_cells));
for (std::vector<Cell_handle>::iterator
cit=incident_cells.begin();
cit!=incident_cells.end();
++cit)
if (c3t3.triangulation().is_infinite(*cit)){
is_on_chull=true;
continue;
int index=(*cit)->index(vit);
K::Triangle_3
triangle((*cit)->vertex((index+1)%4)->point(),
(*cit)->vertex((index+2)%4)->point(),
(*cit)->vertex((index+3)%4)->point());
Kernel::Triangle_3 tr2=to_exact(triangle);
if( CGAL::do_intersect(line_vertex,tr2) )
++nb_inter;
//or CGAL_assertion
if( ((is_on_chull&& nb_inter==1) || (!is_on_chull&&
nb_inter==2))==true ){
std::cout<<"OK"<<std::endl;
else {
std::cout<<"ERRORINTERSEC"<<std::endl;
return 0;
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
