cgal-discuss - [cgal-discuss] Re: Infinite vertex in Triangulations
  • To:
  • Subject: [cgal-discuss] Re: Infinite vertex in Triangulations
  • Date: Wed, 10 Aug 2011 09:49:06 -0700 (PDT)
Hello,
I have also come across a peculiarity regarding the infinite_vertex, which I
am hoping you might be able to clear up for me.
Similar to the other posts, in my case it seems that not all connected
components of a Tetmesh are connected with the infinite vertex.
I create my Tetmesh using the incremental builder (for details see below),
as a simple example I created 2 Tets which are simply translates of
eachother:
Vertices
8
0 0 0 0
1 0 0 0
0 1 0 0
0 0 1 0
2 0 0 0
3 0 0 0
2 1 0 0
2 0 1 0
Tetrahedra
2
1 2 3 4
5 6 7 8
now the outputting the number of elements yield the following:
#vertices: 8
#edges : 20
#faces : 20
#cells : 10
while the number of vertices seems ok, the rest seems odd!?
Furthermore, outputting the number of /incident_cells/ to the
/infinite_vertex/ yields:
#cells incident to inf vertex = 4
The "problem" occurred to me when trying to visualize the outer surface
mesh(es) (of a multi-component tetmesh) using incidence with the infinite
vertex...
Can someone please tell me if this is the wanted functionality and/or if I
am simply using the Triangulation/Builder wrong?
Many thanks,
Henrik
The used data structure:
/typedef CGAL::Exact_predicates_inexact_constructions_kernel TM_K;
typedef TVB_with_index<TM_K> TM_VB;
typedef TCB_with_index<TM_K> TM_CB;
typedef CGAL::Triangulation_data_structure_3< TM_VB, TM_CB> TM_TDS;
typedef CGAL::Triangulation_3&lt;TM_K, TM_TDS&gt;
TetMeshT3;
typedef Triangulation_3_with_indices<TetMeshT3> TetMeshCGAL;
typedef CGAL::Triangulation_incremental_builder_3<TetMeshCGAL>
TetMeshCGALIncrementalBuilder;/
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Infinite-vertex-in-Triangulations-tp1015702p3733540.html
