cgal-discuss - Re: [cgal-discuss] Re: Infinite vertex in Triangulations
  • To:
  • Subject: Re: [cgal-discuss] Re: Infinite vertex in Triangulations
  • Date: Tue, 16 Aug 2011 15:52:54 +0200
Hi,
Let me recall that the infinite vertex is adjacent to each vertex of the _convex hull_ of your input points.
So, the fact that you have 2 tetrahedra as input does not imply that you have 8 infinite cells in the 3D triangulation of your 8 input points.
Best,
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
Le 15/08/11 11:09, henrikz a écrit :
Using only one tetrahedron I get the numbers you mention:
#vertices: 4 (+ 1)
#edges : 10
#faces : 10
#cells : 5
furthermore I get #cells incident to inf vertex = 4, which makes sense.
Yes, in my previous example I had twice these numbers, BUT STILL the same
which is (probably) my problem.
I was not trying to build one but TWO (disjoint) tetrahedra, so I was
expecting the number of cells that are connected to the infinite vertex to
also double!?
Possibly I am using the incremental builder wrong, but it only offers
/add_vertex/ and /add_cell/ so I don't really believe it.
Actually I have a very simple reader which just parses the following format
/ Vertices
8
0 0 0 0
1 0 0 0
0 1 0 0
0 0 1 0
2 0 0 0
3 0 0 0
2 1 0 0
2 0 1 0
Tetrahedra
2
1 2 3 4
5 6 7 8 /
by first adding 8 vertices and then simply adding 2 cells.
I could restate my questions slightly: is it true that every boundary face
of finite tetrahedra are connected to the infinite vertex by a (different)
infinite cell?
Because in that case I would expect
/VH vh_inf = mesh_.infinite_vertex();
std::vector<CH> inf_cells;
mesh_.incident_cells(vh_inf, std::back_inserter(inf_cells) );
std::cerr<< "cells incident to inf vertex "<< inf_cells.size()<<
std::endl;
to yield "8" and NOT "4" for my two disjoint tetrahedra?
Thanks in advance!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Infinite-vertex-in-Triangulations-tp1015702p3744195.html
