- To:
- Subject: Re: [cgal-discuss] make_surface_mesh empty set
- Date: Tue, 16 Aug 2011 10:58:17 +0300
The points should be on the surface. They do not have to be exactly (its ok to use double arithmetic) on the surface, but very close. In case your surface has several connected components, make sure that you have several points on each.
best,
Michael
On Mon, Aug 15, 2011 at 8:39 PM, Richard Downe <> wrote:
I appreciate the insight.
Yes, when it fails it terminates very fast. I had seen the 20 point initialization, and had lifted the value verbatim from the sample code; I will try increasing the number, though I can definitely provide a traits class with more consistent initialization points.
One question, though: if I derive my own traits class, should the points be on the surface, inside the enclosed volume, or a combination of the two, such that the generated tetrahedra intersect the surface to be resampled?
--rd--
On 08/15/2011 04:32 AM, Michael Hemmer wrote:
Hi,
I am not the expert for the package but, AFAIK, the experts are on
vacation. Here is my guess:
In the beginning of the process the point on the surfaces are
generated randomly by shooting random rays. Usually these are 20
points [1]. Sometimes this is not enough. It may happen that all
generated tetrahedra are classified as outside. In this case, no
facet is a boundary facet, which in particular means that there are no
bad facets and the refinement process does not even start. It would
also mean that your process terminates very fast. Is that correct ?
Increasing the number of these initial points may be already
sufficient for you [1].
If this does not help, it may be necessary to chose the initial points
more carefully. That is, you provide your own traits class, based on
the one that you are using at the moment, but with your own
implementation of SurfaceMeshTraits_3::Construct_initial_points [2].
hope that helps,
Michael Hemmer
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesher_ref/Function_make_surface_mesh.html#Cross_link_anchor_1460
[2] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesher_ref/Concept_SurfaceMeshTraits_3.html#Cross_link_anchor_1472
On Mon, Aug 15, 2011 at 5:27 AM, Richard Downe<> wrote:
In running surface mesh resampling using the example taken from the
Polyhedron demos in CGAL 3.8, I normally get a good result, but with
alarming frequency and apparently nondeterministic cause, I sometimes get an
empty set (e.g., the C2t3 contains 0 facets after reconstruction completes).
Sometimes running the program a second time causes a correct result to
emerge. Is there anything I can do to tune the algorithm to ensure that I
always get a valid result?
--rd
- [cgal-discuss] make_surface_mesh empty set, Richard Downe, 08/15/2011
- Re: [cgal-discuss] make_surface_mesh empty set, Michael Hemmer, 08/15/2011
- Re: [cgal-discuss] make_surface_mesh empty set, Richard Downe, 08/15/2011
- Re: [cgal-discuss] make_surface_mesh empty set, Michael Hemmer, 08/16/2011
- Re: [cgal-discuss] make_surface_mesh empty set, Laurent Rineau (GeometryFactory), 08/16/2011
- Re: [cgal-discuss] make_surface_mesh empty set, Richard Downe, 08/17/2011
