cgal-discuss - [cgal-discuss] make_surface_mesh empty set
  • To: <>
  • Subject: [cgal-discuss] make_surface_mesh empty set
  • Date: Sun, 14 Aug 2011 21:27:13 -0500
In running surface mesh resampling using the example taken from the Polyhedron demos in CGAL 3.8, I normally get a good result, but with alarming frequency and apparently nondeterministic cause, I sometimes get an empty set (e.g., the C2t3 contains 0 facets after reconstruction completes). Sometimes running the program a second time causes a correct result to emerge. Is there anything I can do to tune the algorithm to ensure that I always get a valid result?
--rd
