cgal-discuss - Re: [cgal-discuss] Algorithm of CGAL::make_surface_mesh
  • To:
  • Subject: Re: [cgal-discuss] Algorithm of CGAL::make_surface_mesh
  • Date: Fri, 19 Aug 2011 15:11:25 +0200
On mercredi 10 août 2011 09:12:55 kyewong wrote:
> Hi, I'm gonna use CGAL::make_surface_mesh to mesh an implicit surface,
> extract the isosurface and convert it to Polyhedron_3 using
> CGAL::output_surface_facets_to_polyhedron.
> I noticed that the algorithm for extracting the isosurface from a given
> implicit surface is the paper <Provably good sampling and meshing of
> surfaces>.
> However, I'm just wondering how about the result and stability of this
> algorithm, comparing to the famous marching cube method used by Jules
> Bloomenthal ? Is it fit for any type of implicit function?
> Thanks!
This algorithm of CGAL::make_surface_mesh is designed for smooth implicit
surfaces. If your implicit surface is not smooth, then the sharp features of
the surface will not be meshed correctly. Worst: if your implicit surface is
not manifold and you activate the manifold criterion, then the algorithm may
loop and eventually crash.
What is more, if the implicit surface has several connected components, the
result of the meshing is not guaranteed to mesh all connected components of
the surface. The initial step should be carreful to add a few points to every
connected components.
Laurent Rineau, PhD
