- To:
- Subject: [cgal-discuss] libboost dependencies in Ubuntu 11.04
- Date: Fri, 19 Aug 2011 09:49:35 -0700 (PDT)
Hello,
I am working for a university project and part of it requires cgal.
I'm using Ubuntu 11.04 and cgal can be installed directly through Ubuntu's
package management system, in my case using Synaptic. I install libcgal-dev
(version 3.6.1), which asks for libboost-dev and libboost1.42-dev as
dependencies. Now, you must know that the project I'm working on also
requires a boost version newer than 1.42, at least 1.44. So, when I install
libcgal-dev and its dependencies, it gives me the error:
E: /var/cache/apt/archives/libboost1.42-dev_1.42.0-4ubuntu2_i386.deb: trying
to overwrite '/usr/include/boost/exception.hpp', which is also in package
libboost-exception-dev 110812-natty
I can then use cgal, as it is kind of installed, but Ubuntu will continue to
say that there is a broken package and I must fix it before I can update or
install any other package. So, I always need to uninstall cgal, reinstall
libboost-dev (which resolves the actual "broken dependencies" error), do my
updates/installs and then reinstall cgal, resulting in a broken dependency,
again.
Somebody from #ubuntu on freenode recommended to write to the list, as this
might be a bug. Can it be, for example, that libcgal-dev in version 3.6.1
requires libboost-dev's version to be equal to 1.42 and not equal or newer
than 1.42?
Thanks for your attention and have a nice day,
Manuel
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/libboost-dependencies-in-Ubuntu-11-04-tp3755646p3755646.html
- [cgal-discuss] libboost dependencies in Ubuntu 11.04, mm, 08/19/2011
- Re: [cgal-discuss] libboost dependencies in Ubuntu 11.04, Amy Louise Tabb, 08/19/2011
- Re: [cgal-discuss] libboost dependencies in Ubuntu 11.04, Joachim Reichel, 08/19/2011
- [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, mm, 08/22/2011
- Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, Philipp Möller, 08/22/2011
- Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, Laurent Rineau (GeometryFactory), 08/22/2011
