cgal-discuss - [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04
  • To:
  • Subject: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04
  • Date: Mon, 22 Aug 2011 07:13:39 -0700 (PDT)
Laurent Rineau (GeometryFactory) wrote:
> On lundi 22 août 2011 14:11:36 mm wrote:
>> Amy Tabb wrote:
>> > My opinion of how to fix your problem is to keep the newest version of
>> > boost (at least 1.44), and then skip the Synaptic package manager
>> version
>> > of cgal and instead build it from source. In the cmake dialog, you can
>> > manually point to the specific version of boost that you have, but when
>> I
>> > have installed it on Ubuntu there was no need to alter the libraries
>> > found by cmake.
>> > Then you'll have the most up to date version of boost with the most up
>> to
>> > date version of cgal, the only negative being some long download and
>> > build times.
>> Joachim Reichel wrote:
>> > If you don't want to/can't do that yourself there seem to be two
>> options:
>> > 1) Build CGAL yourself from source, as recommended by Amy.
>> > 2) Use a newer CGAL package from Ubuntu oneiric or Debian squeeze (CGAL
>> > 3.8 / Boost 1.46).
>> Hey Amy and Joachim, thanks for answering that fast! My response comes a
>> bit late, but I was afk all weekend long.
>> What both of you said makes total sense and I'd like to follow Amy's
>> recommendation and compile CGAL from source and link against that.
>> Unfortunately, it's not working. Setup is like this:
>> 1) downloaded
>> https://gforge.inria.fr/frs/download.php/28501/CGAL-3.8.tar.xz 2)
>> unpacked
>> and called cmake: only option changed is:
>> CMAKE_INSTALL_PREFIX = /home/mm/.local/CGAL-3.8/
>> as that's the place I keep my selfcompiled software.
>> 3) open my project in cmake and set
>> CGAL_DIR = /home/mm/.local/CGAL-3.8/lib/CGAL
>> It's the only CGAL option and originally when I install CGAL through
>> Synaptic, the folder /usr/lib/CGAL contains the same files, mostly
>> *.cmake
>> or *.in files.
>> 4) compile my project and get error:
>> /home/mm/code/src/cv/reflectance/illumestimators/gamutmapping/gamutmapping2
>> destimator.cpp:14:64: fatal error:
>> CGAL/Exact_predicates_inexact_constructions_kernel.h: No such file or
>> directory
>> compilation terminated.
> Between steps 2 and 3, have you compiled CGAL libraries? Do you have a
> file
> /home/mm/.local/CGAL-3.8/lib/CGAL/CGALConfig.cmake? What is the value of
> variable CGAL_INCLUDE_DIRS in that file?
> The CMake lines about in your CMakeLists.txt seem correct.
Oh, forgot that: yeah, I compiled CGAL between steps 2 and 3. :)
The file /home/mm/.local/CGAL-3.8/lib/CGAL/CGALConfig.cmake exists and the
mentioned line looks like this:
set(CGAL_INCLUDE_DIRS "/home/mm/.local/CGAL-3.8//include" )
So, this looks just fine and is the correct path.
I'm kind of out of ideas... I compared the explicit compiler lines for the
file that includes the CGAL things. Here the includes in the file
gamutmapping2destimator.cpp:
#include &lt;CGAL/Exact_predicates_inexact_constructions_kernel.h&gt;
#include &lt;CGAL/point_generators_2.h&gt;
#include &lt;CGAL/algorithm.h&gt;
#include &lt;CGAL/convex_hull_traits_2.h&gt;
#include &lt;CGAL/convex_hull_2.h&gt;
#include &lt;CGAL/Exact_predicates_exact_constructions_kernel.h&gt;
and here the compiler line:
[ 72%] Building CXX object
illumestimators/CMakeFiles/illumestimators-lib.dir/gamutmapping/gamutmapping2destimator.cpp.o
cd /home/mm/code/build/cv/vole/illumestimators && /usr/bin/c++
-DOPENCV_VERSION=2.2.0 -DWITH_OPENCV2 -DWITH_OPENCV -DWITH_QT
-DWITH_QT_OPENGL -DWITH_QT_XML -DWITH_BOOST -DWITH_BOOST_SYSTEM
-DWITH_BOOST_FILESYSTEM -DWITH_BOOST_PROGRAM_OPTIONS
-DWITH_BOOST_SERIALIZATION -DWITH_BOOST_THREAD -DWITH_CGAL -DWITH_QHULL
-DWITH_LPSOLVE -g -O2 -D_REENTRANT -frounding-math -O3 -DNDEBUG
-I/usr/local/include/opencv -I/usr/local/include -I/usr/include/qt4
-I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui
-I/usr/include/qt4/QtOpenGL -I/usr/include/qt4/QtXml -I/usr/include/include
-I/home/mm/code/src/cv/vole/core/common
-I/home/mm/code/src/cv/vole/core/storage
-I/home/mm/code/src/cv/vole/core/shell
-I/home/mm/code/src/cv/vole/modules/vlfeat
-I/home/mm/code/src/cv/vole/modules/csparse
-I/home/mm/code/src/cv/vole/modules/superpixels
-I/home/mm/code/src/cv/vole/modules/sift
-I/home/mm/code/src/cv/vole/modules/seg_felzenszwalb
-I/home/mm/code/src/cv/vole/modules/similarity_measures
-I/home/mm/code/src/cv/vole/modules/color_processing
-I/home/mm/code/src/cv/vole/modules/seg_graphs
-I/home/mm/code/src/cv/reflectance/crf
-I/home/mm/code/src/cv/reflectance/gt_multi_illum
-I/home/mm/code/src/cv/reflectance/skinrefl
-I/home/mm/code/src/cv/reflectance/ms_edges
-I/home/mm/code/src/cv/reflectance/postseg
-I/home/mm/code/src/cv/reflectance/iebv
-I/home/mm/code/src/cv/reflectance/muil
-I/home/mm/code/src/cv/reflectance/illumestimators/iic/gui
-I/home/mm/code/src/cv/reflectance/illumestimators/iic/commands
-I/home/mm/code/src/cv/reflectance/illumestimators/iic/misc
-I/home/mm/code/src/cv/reflectance/illumestimators/iic/mask
-I/home/mm/code/src/cv/reflectance/illumestimators/iic/estimator
-I/home/mm/code/src/cv/reflectance/specularity_removal
-I/home/mm/code/build/cv/vole/illumestimators -DWITH_ILLUMESTIMATORS
-DWITH_SUPERPIXELS -DWITH_CACHE -DWITH_GT_M_ILLUM -o
-c
/home/mm/code/src/cv/reflectance/illumestimators/gamutmapping/gamutmapping2destimator.cpp
It was the same for both, ubuntu CGAL and own compiled CGAL.
But, inspecting the above compiler line, Philipp might be right that the
compiler is still not searching in the right place for include headers...
But I have no idea why or how I should change that? Adding the explicit path
/home/mm/.local/CGAL-3.8/include to $PATH seems a bit weird, as you normally
don't have to do that for other libs...?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/libboost-dependencies-in-Ubuntu-11-04-tp3755646p3760264.html
