- To:
- Subject: Re: [cgal-discuss] geometry kernels
- Date: Sat, 20 Aug 2011 08:17:35 -0400
Laurent,
I modified examples/Surface_reconstruction_point_3/poisson_reconstruction_example.cpp by replace
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel
with
typedef CGAL::Simple_cartesian<double> Kernel
Yifei
On Fri, Aug 19, 2011 at 9:20 AM, Laurent Rineau (GeometryFactory) <> wrote:
A general answer:On samedi 13 août 2011 08:50:47 Yifei Li wrote:
> Hi,
> I got many compiler errors after I replaced
> Exact_predicates_inexact_constructions_kernel with Simple_cartesian<double>
> in surface reconstruction example.
> What is Simple_cartesian kernel good for then?
http://www.cgal.org/FAQ.html#kernels
However, that is strange that you got compilation errors. Can you tell which
program your were trying to compile and how you modified it?
Laurent Rineau, PhD
- [cgal-discuss] geometry kernels, Yifei Li, 08/13/2011
- Re: [cgal-discuss] geometry kernels, Laurent Rineau (GeometryFactory), 08/19/2011
- Re: [cgal-discuss] geometry kernels, Yifei Li, 08/20/2011
- Re: [cgal-discuss] geometry kernels, Andreas Fabri, 08/22/2011
