cgal-discuss - Re: [cgal-discuss] geometry kernels
  • To:
  • Subject: Re: [cgal-discuss] geometry kernels
  • Date: Mon, 22 Aug 2011 17:24:33 +0200
Hello Yifei,
If you replace at the same time the kernel in the class
Surface_mesh_default_triangulation it compiles,
BUT
We do not recommend to do this, as you switch off efforts
we make to provide robust code.
Best regards,
andreas
On 20/08/2011 14:17, Yifei Li wrote:
Laurent,
I modified
examples/Surface_reconstruction_point_3/poisson_reconstruction_example.cpp
by replace
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel
with
typedef CGAL::Simple_cartesian<double> Kernel
Yifei
On Fri, Aug 19, 2011 at 9:20 AM, Laurent Rineau (GeometryFactory)
<mailto:>>
wrote:
On samedi 13 août 2011 08:50:47 Yifei Li wrote:
> Hi,
> I got many compiler errors after I replaced
> Exact_predicates_inexact_constructions_kernel with
> in surface reconstruction example.
> What is Simple_cartesian kernel good for then?
A general answer:
http://www.cgal.org/FAQ.html#kernels
However, that is strange that you got compilation errors. Can you
tell which
program your were trying to compile and how you modified it?
Laurent Rineau, PhD
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
