cgal-discuss - [cgal-discuss] poly-line variance
  • To:
  • Subject: [cgal-discuss] poly-line variance
  • Date: Thu, 25 Aug 2011 23:43:11 -0400
Hi Y'all,
I have two poly-lines and I am trying to find their - that is, the error of one poly-line as a set of points in terms of distance to the other.
What I do now is pretty terrible: for each poly-line in 1, I find its distance to the other poly-line (which requires looking at every segment) and then I sum the squares of those error-distances. The result is O(N^2).
Does anyone know of a better way to measure how similar one poly-line is to another?
The two poly-lines share end points so I tried taking the signed area of the polygon they form, but I get a lot of false low errors - often the two poly-lines will form one large positive and one large negative area, which makes the error seem artificially low.
cheers
ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://www.x-plane.com/blog/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
