- To:
- Cc:
- Subject: Re: [cgal-discuss] poly-line variance
- Date: Tue, 30 Aug 2011 08:23:04 -0400
Thanks Efi!
As usual, there is a whole literature and it was only the name of one mathematician away. :-)
Follow-up for anyone who cares: the most useful paper I found was one that argues for why spatial indexing can be legal for calculating the Hausdorff between poly-lines. Basically once we know the worst case error, we can limit or spatial queries to only a closer range.
In my case, I can use my silly "variance" measurement and still do this as long as there is a maximum distance beyond which I just want to bail out. (In my case there is, because if the error between two curves is large enough my algorithm is going to bail out.) Indexing the curve comparison improved algorithm performance by about 7.5x - it would be more if the polylines weren't so short.
cheers
Ben
On 8/28/11 11:40 AM,
wrote:
Quoting "Ben Supnik"
Hi Y'all,
I have two poly-lines and I am trying to find their - that is, the
error of one poly-line as a set of points in terms of distance to the
other.
What I do now is pretty terrible: for each poly-line in 1, I find its
distance to the other poly-line (which requires looking at every
segment) and then I sum the squares of those error-distances. The
result is O(N^2).
Does anyone know of a better way to measure how similar one poly-line
is to another?
The two poly-lines share end points so I tried taking the signed area
of the polygon they form, but I get a lot of false low errors - often
the two poly-lines will form one large positive and one large negative
area, which makes the error seem artificially low.
Then why not take the sum of the absolute areas?
Look for Hausdorff distance
(http://en.wikipedia.org/wiki/Hausdorff_distance) and related subjects
within.
cheers
ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://www.x-plane.com/blog/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] poly-line variance, Ben Supnik, 08/26/2011
- Re: [cgal-discuss] poly-line variance, efif, 08/28/2011
- Re: [cgal-discuss] poly-line variance, Ben Supnik, 08/30/2011
- Re: [cgal-discuss] poly-line variance, Vicente Helano, 08/28/2011
