- To:
- Subject: [cgal-discuss] number_of_vertices_in_complex
- Date: Tue, 30 Aug 2011 09:21:00 +0200
In CGAL 3.7 I used to get the number of vertices in the generated mesh
from c3t3.number_of_vertices(). In 3.8 this function is gone and the
similarly named c3t3.number_of_vertices_in_complex()
returns zero, even if the mesh is there (as per the loop over
Finite_vertices_iterator vit = tr.finite_vertices_begin(); vit !=
tr.finite_vertices_end()). How to query the number of vertices
correctly?
Regards,
Dominik
- [cgal-discuss] number_of_vertices_in_complex, Dominik Szczerba, 08/30/2011
- Re: [cgal-discuss] number_of_vertices_in_complex, Andreas Fabri, 08/30/2011
- Re: [cgal-discuss] number_of_vertices_in_complex, Laurent Rineau (GeometryFactory), 08/30/2011
- Re: [cgal-discuss] number_of_vertices_in_complex, Dominik Szczerba, 08/30/2011
