cgal-discuss - Re: [cgal-discuss] Questions about the undocumented polyhedron_cut_plane_3
  • To:
  • Subject: Re: [cgal-discuss] Questions about the undocumented polyhedron_cut_plane_3
  • Date: Thu, 01 Sep 2011 15:48:25 +0200
Nicholas Mario Wardhana wrote:
Hi all,
I would like to know about how CGAL's undocumented
polyhedron_cut_plane_3 function cuts a polyhedron. In particular, what
are the purpose of I_polyhedron_cut_component, and how the result of
I_Construct_point_3 contributes to the general algorithm? It is my
understanding that the latter works on a kind of plane intersection,
but I don't get the idea of how the result is used to determine the
new vertices.
Thank you.
Best regards,
Nicholas
This undocumented function has an inline documentation:
template < class Poly, class Plane, class Traits>
typename Poly::Halfedge_handle
polyhedron_cut_plane_3( Poly& poly,
typename Poly::Halfedge_handle h,
const Plane& plane,
const Traits& traits)
// Cuts the polyhedron `poly' at plane `plane' starting at halfedge `h'.
// Traces the intersection curve of `plane' with `poly' starting at `h',
// cuts `poly' along that intersection curve and deletes the (connected)
// component on the negative side of the plane. The hole created along
// the intersection curve is filled with a new face containing the plane
// and the points in the vertices are computed.
Sebastien.
  • Re: [cgal-discuss] Questions about the undocumented polyhedron_cut_plane_3, Sebastien Loriot (GeometryFactory), 09/01/2011
