cgal-discuss - [cgal-discuss] Using taucs
  • To:
  • Subject: [cgal-discuss] Using taucs
  • Date: Thu, 1 Sep 2011 10:29:12 -0500
Hi everyone,
I'm trying to compile a project which uses TAUCS, I include the following headers:
#include <CGAL/basic.h>
#include <CGAL/Taucs_solver_traits.h>
#include <CGAL/Taucs_fix.h>
#include <CGAL/Taucs_matrix.h>
#include <CGAL/Taucs_vector.h>
and then define some types:
typedef Taucs_matrix<taucs_double> TaucsMatrix;
typedef Taucs_vector<taucs_double> TaucsVector;
typedef Taucs_symmetric_matrix<taucs_double> TaucsSymmetricMatrix;
however I get the following compilation errors:
make poissonimageediting.o
[100%] Building CXX object CMakeFiles/poissonimageediting.dir/poissonimageediting.o
/home/marioyc/GradientSuperresolution/poissonimageediting.cpp:12:9: error: ‘Taucs_matrix’ does not name a type
/home/marioyc/GradientSuperresolution/poissonimageediting.cpp:13:9: error: ‘Taucs_vector’ does not name a type
/home/marioyc/GradientSuperresolution/poissonimageediting.cpp:14:9: error: ‘Taucs_symmetric_matrix’ does not name a type
I'm using CGAL 3.6.1 in Ubuntu 10.04, and I'm compiling using the makefile which cmake gives me from the following CMakeLists.txt
# Created by the script cgal_create_cmake_script
# This is the CMake script for compiling a CGAL application.
project( GradientSuperresolution_example )
CMAKE_MINIMUM_REQUIRED(VERSION 2.4.5)
set(CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true)
if ( COMMAND cmake_policy )
  cmake_policy( SET CMP0003 NEW )
endif()
find_package(CGAL QUIET COMPONENTS Core )
# Include this package's headers first
include_directories (BEFORE .)
if ( CGAL_FOUND )
  include( ${CGAL_USE_FILE} )
  include( CGAL_CreateSingleSourceCGALProgram )
  find_package(TAUCS)
  if(TAUCS_FOUND)
    include( ${TAUCS_USE_FILE} )
    # Executables that require TAUCS (thus BLAS and LAPACK)
    create_single_source_cgal_program( "poissonimageediting.cpp" )
  else(TAUCS_FOUND)
    message(STATUS "NOTICE: This directory requires the TAUCS library, and some features will not be available.")
  endif(TAUCS_FOUND)
else()
    message(STATUS "This program requires the CGAL library, and will not be compiled.")
endif()
Mario Ynocente Castro
Undergraduate Student of System Engineering
National University of Engineering, Peru
