cgal-discuss - Re: [cgal-discuss] make_surface_mesh fails
  • To:
  • Subject: Re: [cgal-discuss] make_surface_mesh fails
  • Date: Mon, 5 Sep 2011 17:03:05 +0200
On dimanche 04 septembre 2011 10:21:10 Zohar wrote:
> Hi,
> First congratulation on the forum interface, it's more convenient.
> Second I have a problem with make_surface_mesh when reconstructing from an
> implicit function. When I want higher resolution, i.e. I decrease the
> radius or distance bounds in the criteria, it fails with:
> CGAL::Polyhedron_incremental_builder_3<HDS>::
> lookup_halfedge(): input error: facet 2960 shares a halfedge from vertex
> 3581 to vertex 351 with facet 1784.
I guess your iso-surface is not manifold. What is the implicit function?
> So I thought instead of using Exact_predicates_inexact_constructions_kernel
> to use Exact_predicates_exact_constructions_kernel, but I had compilation
> problems. I fixed them with changing in:
> , but when I ran it with the changes, it just ran forever.
make_surface_mesh is really not designed to run with the "exact-exact
kernel".
The meshing algorithm is iterative, and the coordinates a point at a step is
computed from points inserted before in the triangulation. With the exact-
exact kernel, that means that the construction graph of new points will be
bigger and bigger, and that both the memory consumtion and the running time
are O(n^m) with a big m.
Laurent Rineau, PhD
