cgal-discuss - [cgal-discuss] Algebraic_kernel_d_1 and multi threading with OpenMP
  • To:
  • Subject: [cgal-discuss] Algebraic_kernel_d_1 and multi threading with OpenMP
  • Date: Mon, 5 Sep 2011 23:58:13 +0200 (CEST)
Hello,
I use the Algebraic_kernel_d_1 of CGAL for solving degree 4 equations.
When I use the solver in a #pragma omp parallel for directive,  I have a segmentation fault.
However, I have no issue when there is only one thread.
I attached an example.
Thank you.
Tom.
#ifndef CGAL_USE_MPFI
#define CGAL_USE_MPFI
#endif
#ifdef CGAL_USE_MPFI
#include <CGAL/Algebraic_kernel_d_1.h>
#include <CGAL/Gmpz.h>
#include <omp.h>
#define M 100000
typedef CGAL::Gmpz                            Gmpz;
typedef CGAL::Algebraic_kernel_d_1<Gmpz>      AK_1;
typedef AK_1::Algebraic_real_1                Algebraic_real_1;
typedef AK_1::Polynomial_1                    Polynomial_1;
typedef AK_1::Solve_1                         Solve_1;
int main()
  AK_1 ak;
  Solve_1 solver = ak.solve_1_object();
  for(unsigned i = 0; i < M; i++){
    std::vector<Algebraic_real_1> roots;
    Polynomial_1 l = CGAL::shift(Polynomial_1(1),1);
    Polynomial_1 P = l*l - 1;
    solver(P,false,std::back_inserter(roots));
  return 0;
#else
int main()
  std::cout << "This example requires CGAL to be configured with library MPFI." << std::endl;
  return 0;
#endif
