Re: [cgal-discuss] Bug: Several calls of Poisson surface reconstruction in one application
- To:
- Subject: Re: [cgal-discuss] Bug: Several calls of Poisson surface reconstruction in one application
- Date: Wed, 21 Sep 2011 10:35:58 +0200
Hi Marc,
This is not a known bug in CGAL. I invite you to use a memory debugger (e.g.
valgrind on Unix or AQTime on Windows) to nail down the problem.
Best regards,
Laurent Saboret
Le 21/09/2011 10:26, Marc Klopfenstein a écrit :
Hi,
I am calling several time the Poisson surface reconstruction in my
application. Every time I use the same point set. After n calls the
reconstruction fails (Error: cannot solve Poisson equation) and at the next
reconstruction call I have a crash. I have this problem, when I use
different point set and when I use different point set for each
reconstruction call.
Is this problem a CGAL bug ? See attached a source code pointing out the
problem and a point set for test.
Best Regards,
Marc
http://cgal-discuss.949826.n4.nabble.com/file/n3829299/1.xyz 1.xyz
http://cgal-discuss.949826.n4.nabble.com/file/n3829299/main.cpp main.cpp
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-Several-calls-of-Poisson-surface-reconstruction-in-one-application-tp3829299p3829299.html
- [cgal-discuss] Bug: Several calls of Poisson surface reconstruction in one application, Marc Klopfenstein, 09/21/2011
- Re: [cgal-discuss] Bug: Several calls of Poisson surface reconstruction in one application, Laurent Saboret, 09/21/2011
- [cgal-discuss] Re: Bug: Several calls of Poisson surface reconstruction in one application, Marc Klopfenstein, 09/30/2011
- Re: [cgal-discuss] Re: Bug: Several calls of Poisson surface reconstruction in one application, Sebastien Loriot (GeometryFactory), 09/30/2011
