cgal-discuss - Re: [cgal-discuss] Re: Bug: Several calls of Poisson surface reconstruction in one application
  • To:
  • Subject: Re: [cgal-discuss] Re: Bug: Several calls of Poisson surface reconstruction in one application
  • Date: Fri, 30 Sep 2011 10:51:11 +0200
Thanks Marc for the update.
We don't want to fix problems in TAUCS, so right now
we cannot do much.
Note that for the new release, we plan to replace the default
sparse solver in Poisson reconstruction by Eigen (which should be
faster and safe).
If you are interested we can provide you the new (still experimental)
version so that you can give us feedback on it.
Sebastien.
Marc Klopfenstein wrote:
Hi
I run PURIFY for my problem. There are invalid pointer and read of
uninitialized pointer in Taucs.
See attached the result:
http://cgal-discuss.949826.n4.nabble.com/file/n3859179/Test_generateur4.txt
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-Several-calls-of-Poisson-surface-reconstruction-in-one-application-tp3829299p3859179.html
