Re: [cgal-discuss] do_intersect name lookup problem when using multiple kernels
- To:
- Subject: Re: [cgal-discuss] do_intersect name lookup problem when using multiple kernels
- Date: Thu, 22 Sep 2011 09:58:44 +0200
A golden rule in CGAL is that CGAL/basic.h should be included before
any other CGAL header (or a CGAL kernel that include CGAL/basic.h)
See 2.4
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Preliminaries/Chapter_main.html
Sebastien.
On 09/21/2011 10:32 PM, Frankie Li wrote:
Hi all,
I was wondering if anyone has seen the following problem. The version of
CGAL I have been using primarily are 3.5.1 and 3.6.
In the AABB_tree example ("AABB_triangle_3_example.cpp"), if we add an
include for "exact predicates inexact constructions kernel in front of
the <CGAL/AABB_traits.h> include:
#include <iostream>
#include <list>
#include <CGAL/AABB_tree.h> // must be inserted before kernel
//^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ line added
#include <CGAL/AABB_traits.h>
#include <CGAL/AABB_triangle_primitive.h>
#include <CGAL/Simple_cartesian.h>
I would end up with the following error:
function_objects.h:1869: error: no matching function for call to
'do_intersect(const CGAL::Sphere_3<CGAL::Simple_cartesian<double> >&,
const CGAL::Bbox_3&, CGAL::Simple_cartesian<double>)'
If I were to move the new line to *after* <CGAL/AABB_traits.h>
#include <iostream>
#include <list>
The problem goes away. Am I not supposed to have the two files included
at the same time? The version of gcc I'm using is gcc 4.4.5.
Thanks,
Frankie
- [cgal-discuss] do_intersect name lookup problem when using multiple kernels, Frankie Li, 09/21/2011
- Re: [cgal-discuss] do_intersect name lookup problem when using multiple kernels, Sebastien Loriot (GeometryFactory), 09/22/2011
- Re: [cgal-discuss] do_intersect name lookup problem when using multiple kernels, Frankie Li, 09/22/2011
