- To:
- Subject: Re: [cgal-discuss] I have a problem with examples of CGAL
- Date: Wed, 28 Sep 2011 23:42:58 -0400
Hi, everybody. How to randmonly generate N person with a certain diameter in continuous space, not space consisted of cells.
Thanks.
I thought that installation was success because I build the few examples successfully.
However, bulk of examples are has an error like this.
No. 1 - 1>LINK : fatal error LNK1104: cannot open file 'gmp-vc90-mt-gd.lib'
No. 2 - 1>CGAL-vc90-mt-gd.lib(all_files.obj) : error LNK2019: unresolved external symbol "void __cdecl boost::detail::set_tss_data(void const *,class boost::shared_ptr<struct boost::detail::tss_cleanup_function>,void *,bool)" (?set_tss_data@detail@boost@@YAXPEBXV?$shared_ptr@Utss_cleanup_function@detail@boost@@@2@PEAX_N@Z) referenced in function "public: void __cdecl boost::thread_specific_ptr<int>::reset(int *)" (?reset@?$thread_specific_ptr@H@boost@@QEAAXPEAH@Z)
I found few coments to solve this problem on the internet. The contents of the coment was installation of boost - bjam.
However, I failed to install the bjam because of the root(the program skipped all the files).
I installed CGAL version 3.8, boost is 1.40, Qt4 is 4.7.4 and cmake is 2.8.5.
The environment of my computer is windows 7 - 64 bit and the version of visual studio is 2008(9.0).
Please help me.
- [cgal-discuss] I have a problem with examples of CGAL, 유수홍, 09/29/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] I have a problem with examples of CGAL, mingjun liao, 09/29/2011
- Re: [cgal-discuss] I have a problem with examples of CGAL, Sebastien Loriot (GeometryFactory), 09/29/2011
- RE: Re: [cgal-discuss] I have a problem with examples of CGAL, 유수홍, 09/29/2011
