- To: <>
- Subject: RE: Re: [cgal-discuss] I have a problem with examples of CGAL
- Date: Thu, 29 Sep 2011 20:43:10 +0900
- Importance: normal
Thank you for your reply.
I did mistake. I did not include the examples when I configure using CMAKE.
However another problem occured.
447>LINK : fatal error LNK1104: cannot open file 'gmp-vc90-mt-gd.lib'
How can I solve this problem?
-----Original Message-----
To:
Cc:
Sent: 11-09-29(목) 15:22:20
Subject: Re: [cgal-discuss] I have a problem with examples of CGAL
So the CGAL library has been built correctly?
Did you use cmake to configure examples that fail to compile?
Sebastien.
유수홍 wrote:
> I thought that installation was success because I build the few examples
> successfully.
> However, bulk of examples are has an error like this.
> No. 1 - 1>LINK : fatal error LNK1104: cannot open file 'gmp-vc90-mt-gd.lib'
> No. 2 - 1>CGAL-vc90-mt-gd.lib(all_files.obj) : error LNK2019: unresolved
> external symbol "void __cdecl boost::detail::set_tss_data(void const
> *,class boost::shared_ptr
> (?set_tss_data@detail@boost@@YAXPEBXV?$shared_ptr@Utss_cleanup_function@detail@boost@@@2@PEAX_N@Z)
> referenced in function "public: void __cdecl
> boost::thread_specific_ptr
> (?reset@?$thread_specific_ptr@H@boost@@QEAAXPEAH@Z)
> I found few coments to solve this problem on the internet. The contents
> of the coment was installation of boost - bjam.
> However, I failed to install the bjam because of the root(the
> program skipped all the files).
> I installed CGAL version 3.8, boost is 1.40, Qt4 is 4.7.4 and cmake is
> 2.8.5.
> The environment of my computer is windows 7 - 64 bit and the version of
> visual studio is 2008(9.0).
> Please help me.
- [cgal-discuss] I have a problem with examples of CGAL, 유수홍, 09/29/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] I have a problem with examples of CGAL, mingjun liao, 09/29/2011
- Re: [cgal-discuss] I have a problem with examples of CGAL, Sebastien Loriot (GeometryFactory), 09/29/2011
- RE: Re: [cgal-discuss] I have a problem with examples of CGAL, 유수홍, 09/29/2011
