cgal-discuss - [cgal-discuss] cgal half-edge limitations
  • To:
  • Subject: [cgal-discuss] cgal half-edge limitations
  • Date: Fri, 30 Sep 2011 15:05:10 -0700
I had a quick question regarding the half-edge data structure present
in CGAL. I've read over the documentation several times and
understand that the mesh must be 2-manifold and doesn't support holes
inside facets, which is fine. What I couldn't find however, was
whether the structure supports singular vertices, where one vertex is
attached to multiple non-joining facets.
For the vertex in the middle bridging the two facets, it will only
point to an edge on one of the two faces. Looking over the API, I
don't see anything that allows lookup of the other face given just the
vertex. Is this not a supported mesh configuration in CGAL's
half-edge implementation, or is it okay, but requires additional code
to handle these cases?
