- To: "" <>
- Subject: Re: [cgal-discuss] cgal half-edge limitations
- Date: Mon, 03 Oct 2011 13:27:08 +0200
Le 01/10/2011 20:24, Josh Stratton a écrit :
The first is a patch of four quads (say facet A, B, C, and D labeled
from top-left, top-right, bottom-left, bottom-right). This is a
2-manifold surface that can be represented in a polyehdron_3, correct?
So if face B is removed, it is still a 2-manifold polyedron.
Yes.
What would happen in CGAL if facet C is then removed? Would that result in
a run-time error?
No. In Polyhedron_3 the external face is always represented, thus you will obtain the "correct result", since the internal represented object has three faces (A, D and the external one) and thus is a 2-manifold.
On Sat, Oct 1, 2011 at 9:35 AM, Guillaume Damiand
wrote:
Le 01/10/2011 00:05, Josh Stratton a écrit :
I had a quick question regarding the half-edge data structure presentI don't understand your first example.
in CGAL. I've read over the documentation several times and
understand that the mesh must be 2-manifold and doesn't support holes
inside facets, which is fine. What I couldn't find however, was
whether the structure supports singular vertices, where one vertex is
attached to multiple non-joining facets.
For the vertex in the middle bridging the two facets, it will only
point to an edge on one of the two faces. Looking over the API, I
don't see anything that allows lookup of the other face given just the
vertex. Is this not a supported mesh configuration in CGAL's
half-edge implementation, or is it okay, but requires additional code
to handle these cases?
The second one is not a 2-manifold, thus it can not be represented by a
Polyhedron_3 (by definition).
You can add the surrounding face englobing your two squares => you obtain a
2 manifold and thus one vertex (this is probably always the case for
Polyhedron_3 but I am not sure...)
Guillaume DAMIAND
LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
- [cgal-discuss] cgal half-edge limitations, Josh Stratton, 10/01/2011
- Re: [cgal-discuss] cgal half-edge limitations, Guillaume Damiand, 10/01/2011
- Re: [cgal-discuss] cgal half-edge limitations, Josh Stratton, 10/01/2011
- Re: [cgal-discuss] cgal half-edge limitations, Guillaume Damiand, 10/03/2011
