- To:
- Subject: Re: [cgal-discuss] problem with CGAL and CMAKE - mostly SOLVED
- Date: Mon, 03 Oct 2011 01:50:42 +0200
Hi, I have probably found the reason of unresolved externals: While instaling CGAL, I had installed a 64bit version of auxiliary libraries. After instalation of 32bit version, I can compile my code (on my 64 bit system). But the warnings remained: WARNING: Target "example_2" requests linking to directory "D:/winappl/CGAL/lib/". Targets may link only to libraries. CMake is dropping the item. I will be glad if somebody knows he answer. Best regards Petr Dne 2.10.2011 12:35, Petr Felkel napsal(a): Hi, |
- [cgal-discuss] problem with CGAL and CMAKE, Petr Felkel, 10/02/2011
- Re: [cgal-discuss] problem with CGAL and CMAKE - mostly SOLVED, Petr Felkel, 10/03/2011
- Re: [cgal-discuss] problem with CGAL and CMAKE - mostly SOLVED, Sebastien Loriot (GeometryFactory), 10/03/2011
- Re: [cgal-discuss] problem with CGAL and CMAKE - mostly SOLVED, Sebastien Loriot (GeometryFactory), 10/12/2011
- Re: [cgal-discuss] problem with CGAL and CMAKE - mostly SOLVED, Petr Felkel, 10/12/2011
