cgal-discuss - Re: [cgal-discuss] problem with CGAL and CMAKE - mostly SOLVED
  • To:
  • Subject: Re: [cgal-discuss] problem with CGAL and CMAKE - mostly SOLVED
  • Date: Mon, 03 Oct 2011 12:42:51 +0200
Thank you for your answer.
Yes, I know, library settings in config is strange. But what shal I do with it?
While configuring CGAL I have:
  1. started cmake-gui .. in subdirectory of CGAL-3.8 sources.
  2. selected File/Delete Cache
  3. pressed Configure two times
  4. modified the variables
    WITH_CGAL_Qt3 - unclicked
    CMAKE_INSTALL_PREFIX   = D:/winappl/CGAL
    ZLIB_INCLUDE_DIR             = D:/winappl/zlib/include
    ZLIB_INCLUDE_LIBRARY    = D:/winappl/zlib/lib/zdll.lib
  5. pressed configure once
There were warnings:
Boost include: d:/winappl/boost_1_47
Boost libraries: optimized;d:/winappl/boost_1_47/lib/libboost_thread-vc100-mt-1_47.lib;debug;d:/winappl/boost_1_47/lib/libboost_thread-vc100-mt-gd-1_47.lib
Boost definitions:
USING BOOST_VERSION = '1.47.0'
CMake Warning (dev) at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:85 (INCLUDE):
File C:/Program Files (x86)/CMake
2.8/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake includes
D:/winappl/CGAL-3.8/cmake/modules/FindPackageMessage.cmake (found via
CMAKE_MODULE_PATH) which shadows C:/Program Files (x86)/CMake
2.8/share/cmake-2.8/Modules/FindPackageMessage.cmake. This may cause
errors later on .
Policy CMP0017 is not set: Prefer files from the CMake module directory
when including from there. Run "cmake --help-policy CMP0017" for policy
details. Use the cmake_policy command to set the policy and suppress this
warning.
Call Stack (most recent call first):
C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindZLIB.cmake:69 (INCLUDE)
src/CGALimageIO/CMakeLists.txt:16 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
Found ZLIB: D:/winappl/zlib/lib/zdll.lib (found version "1.2.5")
OpenGL include:
OpenGL libraries: glu32;opengl32
USING ZLIB_VERSION = '1.2.5'
ZLib include: D:/winappl/zlib/include
ZLib libraries: D:/winappl/zlib/lib/zdll.lib
errors later on .
warning.
C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindQt4.cmake:357 (INCLUDE)
src/CGALQt4/CMakeLists.txt:18 (find_package)
USING QT4_VERSION = '4.7.4'
CGAL_LIBRARY remained not set ( an empty text box)
 6. pressed Generate
Is there anything I am doing wrong?
Many thanks and best regards
Petr
PS: I have put the output from cmake-gui and the resulting CMakeCache.txt in the attachment
Dne 3.10.2011 8:17, Sebastien Loriot (GeometryFactory) napsal(a):
The following in your config is strange:
set(CGAL_LIBRARY         "D:/winappl/CGAL/lib/")
set(CGAL_Core_LIBRARY    "D:/winappl/CGAL/lib/")
set(CGAL_ImageIO_LIBRARY "D:/winappl/CGAL/lib/")
set(CGAL_Qt3_LIBRARY     "D:/winappl/CGAL/lib/" )
set(CGAL_Qt4_LIBRARY     "D:/winappl/CGAL/lib/" )
it should be path to the library. You should probably clear the cmakecache and try configure it again.
Sebastien.
Petr Felkel wrote:
  Hi,
I have probably found the reason of unresolved externals:
While instaling CGAL, I had installed a 64bit version of auxiliary libraries.
After instalation of 32bit version, I can compile my code (on my 64 bit system).
But the warnings remained:
    WARNING: Target "example_2" requests linking to directory "D:/winappl/CGAL/lib/". Targets may     link only to libraries. CMake is dropping the item.
I will be glad if somebody knows he answer.
Best regards
Petr
Dne 2.10.2011 12:35, Petr Felkel napsal(a):
Hi,
I need to migrate to Win7/VS2010 with CGAL.
I have installed CGAL 3.8 with additional libraries, but I cannot compile anything, not even the CGAL examples.
I have tried two slightly different methods for CGAL compilation - with and without CGAL_AUTOLINK_GMP and CGAL_AUTOLINK_MPFR
Both do not work.
Maybe - could be an error in the variables in the main CGAL configuration file (CGALConfig.cmake in d:\winappl\CGAL\lib\CGAL\ directory?:
I thought that these variables will be set by the cmake-gui ..
I put CGALConfig.cmake and CMakeCache.txt as attachments...
Thank you for your help - I try to solve this for more than two weks without any light at the end of the tunnel...
Bets regards
Petr
My two trials:
I. CGAL compiled with CGAL_AUTOLINK_GMPand CGAL_AUTOLINK_MPFR unclicked
   1. CGAL: CMAKE-GUI ..
          * Configure / Generate   -- OK
   2. D:/winappl/CGAL-3.8/examples/Triangulation_2
          * CMAKE-GUI .
                o Configure OK
                o Generate full of warnings:
                  WARNING: Target "adding_handles" requests linking to
          * Visual Studio 2010
                o Build Clean
                o Build ALL_BUILD
                  ========= Build: 1 succeeded, 14 failed, 0
                  up-to-date, 1 skipped =========
                  - 121 errors - unresolved external - for example:
                  hierarchy.cpp
                  2>triangulation_prog1.obj : error LNK2019:
                  unresolved external symbol __imp____gmpq_clear
                  referenced in function "public: __thiscall
                  CGAL::Gmpq_rep::~Gmpq_rep(void)"
                  (??1Gmpq_rep@CGAL@@QAE@XZ)
                  unresolved external symbol __imp____gmpq_set_d
                  CGAL::Gmpq::Gmpq(double)" (??0Gmpq@CGAL@@QAE@N@Z)
II. CGAL compiled with CGAL_AUTOLINK_GMPand CGAL_AUTOLINK_MPFR clicked (selected)
          * CMAKE-GUI .
                o Configure OK
                o Generate OK
                o Build Clean
                      + Build ALL_BUILD
                        - the same set of 121 errors - unresolved
                        ========== Build: 2 succeeded, 14 failed, 0
                        up-to-date, 0 skipped ==========
                        9>  hierarchy.cpp
CGAL_MAJOR_VERSION=3
CGAL_MINOR_VERSION=8
CGAL_BUILD_VERSION=
CGAL_SONAME_VERSION=7
CGAL_SOVERSION =7.0.0
CGAL_REFERENCE_CACHE_DIR=
Building static libraries
This is the Windows CMake running within the cygwin platform.
Targetting Visual Studio 10
Target build enviroment supports auto-linking
Using VC10 compiler.
Generator uses intermediate configuration directory: $(Configuration)
USING CMake version: 2.8.5
System: Windows
Build type: Release
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
-D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
-D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except-
/MD /O2 /Ob2 /D NDEBUG'
USING LDFLAGS = ' '
GMP include: D:/winappl/CGAL-3.8/auxiliary/gmp/include
GMP libraries: D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib
GMP definitions:
USING GMP_VERSION = '5.0.1'
MPFR include: D:/winappl/CGAL-3.8/auxiliary/gmp/include
MPFR libraries: D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib
MPFR definitions:
USING MPFR_VERSION = '3.0.0'
Boost libraries:
Boost definitions:
errors later on .
warning.
(INCLUDE)
OpenGL include:
errors later on .
warning.
(INCLUDE)
OpenGL include:
OpenGL definitions:
Qt4 include: D:/winappl/Qt/4.7.4/include
Qt4 libraries:
optimized;D:/winappl/Qt/4.7.4/lib/qtmain.lib;debug;D:/winappl/Qt/4.7.4/lib/qtmaind.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtOpenGL4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtOpenGLd4.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtGui4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtGuid4.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtCore4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtCored4.lib
Qt4 definitions: -DQT_DLL
moc executable: D:/winappl/Qt/4.7.4/bin/moc.exe
uic executable: D:/winappl/Qt/4.7.4/bin/uic.exe
Configuring done
Generating done# This is the CMakeCache file.
# For build in directory: d:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux
# It was generated by CMake: C:/Program Files (x86)/CMake 2.8/bin/cmake.exe
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//Path to a file.
Boost_INCLUDE_DIR:PATH=d:/winappl/boost_1_47
//Boost library directory
Boost_LIBRARY_DIRS:FILEPATH=d:/winappl/boost_1_47/lib;d:/winappl/boost_1_47/lib
//Boost diagnostic define
Boost_LIB_DIAGNOSTIC_DEFINITIONS:STRING=-DBOOST_LIB_DIAGNOSTIC
//The Boost THREAD library
Boost_THREAD_LIBRARY:FILEPATH=optimized;d:/winappl/boost_1_47/lib/libboost_thread-vc100-mt-1_47.lib;debug;d:/winappl/boost_1_47/lib/libboost_thread-vc100-mt-gd-1_47.lib
//Path to a library.
Boost_THREAD_LIBRARY_DEBUG:FILEPATH=d:/winappl/boost_1_47/lib/libboost_thread-vc100-mt-gd-1_47.lib
Boost_THREAD_LIBRARY_RELEASE:FILEPATH=d:/winappl/boost_1_47/lib/libboost_thread-vc100-mt-1_47.lib
//Enable/Disable auto-linking for the external library GMP
CGAL_AUTO_LINK_GMP:BOOL=OFF
//Enable/Disable auto-linking for the external library MPFR
CGAL_AUTO_LINK_MPFR:BOOL=OFF
//Value Computed by CMake
CGAL_BINARY_DIR:STATIC=D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux
//User-defined flags
CGAL_CXX_FLAGS:STRING= -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
CGAL_Core_BINARY_DIR:STATIC=D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/src/CGALCore
//Dependencies for the target
CGAL_Core_LIB_DEPENDS:STATIC=general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib;general;psapi.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib;general;psapi.lib;
CGAL_Core_SOURCE_DIR:STATIC=D:/winappl/CGAL-3.8/src/CGALCore
//Set this to TRUE if you want to define or modify any of CMAKE_*_FLAGS.
// When this is FALSE, all the CMAKE_*_FLAGS flags are overriden
// with the values used when building the CGAL libs. For CGAL_*_flags
// (used for ADDITIONAL flags) , there is no need to set this to
// TRUE.
CGAL_DONT_OVERRIDE_CMAKE_FLAGS:BOOL=TRUE
//The folder where CGAL user-side scripts will be installed, relative
// to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_BIN_DIR:STRING=bin
//The folder where CGAL CMake modules will be installed, relative
CGAL_INSTALL_CMAKE_DIR:STRING=lib/CGAL
//The folder where CGAL documentation and license files will be
// installed, relative to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_DOC_DIR:STRING=share/doc/CGAL-3.8
//The folder where CGAL header files will be installed, relative
CGAL_INSTALL_INC_DIR:STRING=include
//The folder where CGAL libraries will be installed, relative to
// CMAKE_INSTALL_PREFIX
CGAL_INSTALL_LIB_DIR:STRING=lib
//The folder where manual pages for CGAL scripts will be installed,
// relative to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_MAN_DIR:STRING=share/man/man1
CGAL_ImageIO_BINARY_DIR:STATIC=D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/src/CGALimageIO
CGAL_ImageIO_LIB_DEPENDS:STATIC=general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib;general;psapi.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib;general;psapi.lib;general;glu32;general;opengl32;general;D:/winappl/zlib/lib/zdll.lib;
CGAL_ImageIO_SOURCE_DIR:STATIC=D:/winappl/CGAL-3.8/src/CGALimageIO
//The CGAL library
CGAL_LIBRARY:STRING=
CGAL_LIB_DEPENDS:STATIC=general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib;general;psapi.lib;
CGAL_Qt3_BINARY_DIR:STATIC=D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/src/CGALQt
CGAL_Qt3_SOURCE_DIR:STATIC=D:/winappl/CGAL-3.8/src/CGALQt
CGAL_Qt4_BINARY_DIR:STATIC=D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/src/CGALQt4
CGAL_Qt4_LIB_DEPENDS:STATIC=general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib;general;psapi.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib;general;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib;general;psapi.lib;optimized;D:/winappl/Qt/4.7.4/lib/qtmain.lib;debug;D:/winappl/Qt/4.7.4/lib/qtmaind.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtOpenGL4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtOpenGLd4.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtGui4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtGuid4.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtCore4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtCored4.lib;general;glu32;general;opengl32;
CGAL_Qt4_SOURCE_DIR:STATIC=D:/winappl/CGAL-3.8/src/CGALQt4
//soname-version
CGAL_SONAME_VERSION:STRING=7
CGAL_SOURCE_DIR:STATIC=D:/winappl/CGAL-3.8
//soversion
CGAL_SOVERSION:STRING=7.0.0
//For backwards compatibility, what version of CMake commands and
// syntax should this version of CMake try to support.
CMAKE_BACKWARDS_COMPATIBILITY:STRING=2.4
//Build type: Release or Debug
CMAKE_BUILD_TYPE:STRING=Release
//Semicolon separated list of supported configuration types, only
// supports Debug, Release, MinSizeRel, and RelWithDebInfo, anything
// else will be ignored.
CMAKE_CONFIGURATION_TYPES:STRING=Debug;Release;MinSizeRel;RelWithDebInfo
//C++ compiler
CMAKE_CXX_COMPILER:FILEPATH=cl
CMAKE_CXX_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
//Flags used by the compiler during debug builds.
CMAKE_CXX_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1
//Flags used by the compiler during release minsize builds.
CMAKE_CXX_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
//Flags used by the compiler during release builds (/MD /Ob1 /Oi
// /Ot /Oy /Gs will produce slightly less optimized but smaller
// files).
CMAKE_CXX_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
//Flags used by the compiler during Release with Debug Info builds.
CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by defalut with all C++ applications.
CMAKE_CXX_STANDARD_LIBRARIES:STRING='kernel32.lib user32.lib gdi32.lib
winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib
advapi32.lib '
//C compiler
CMAKE_C_COMPILER:FILEPATH=cl
//Flags used by the compiler during all build types.
CMAKE_C_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3 /Zm1000
CMAKE_C_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1
CMAKE_C_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
// files).
CMAKE_C_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by defalut with all C applications.
CMAKE_C_STANDARD_LIBRARIES:STRING='kernel32.lib user32.lib gdi32.lib
advapi32.lib '
//Flags used by the linker.
CMAKE_EXE_LINKER_FLAGS:STRING=' /STACK:10000000 /machine:X86 '
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
//Flags used by the linker during release builds.
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL
//Install path prefix, prepended onto install directories.
CMAKE_INSTALL_PREFIX:PATH=D:/winappl/CGAL
//Path to a program.
CMAKE_LINKER:FILEPATH=d:/winappl/cygwin/bin/link.exe
//make program
CMAKE_MAKE_PROGRAM:FILEPATH=C:/PROGRA~2/MICROS~2.0/Common7/IDE/devenv.com
//Flags used by the linker during the creation of modules.
CMAKE_MODULE_LINKER_FLAGS:STRING=' /STACK:10000000 /machine:X86 '
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL
CMAKE_PROJECT_NAME:STATIC=CGAL
//RC compiler
CMAKE_RC_COMPILER:FILEPATH=rc
//Flags for Fortran compiler.
CMAKE_RC_FLAGS:STRING=' '
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING=' /STACK:10000000 /machine:X86 '
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL
//If set, runtime paths are not added when using shared libraries.
CMAKE_SKIP_RPATH:BOOL=OFF
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make. This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=OFF
//The directory containing the GMP header files
GMP_INCLUDE_DIR:PATH=D:/winappl/CGAL-3.8/auxiliary/gmp/include
//Path to the GMP library
GMP_LIBRARIES:FILEPATH=D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib
GMP_LIBRARIES_DIR:FILEPATH=D:/winappl/CGAL-3.8/auxiliary/gmp/lib
//The directory containing the MPFR header files
MPFR_INCLUDE_DIR:PATH=D:/winappl/CGAL-3.8/auxiliary/gmp/include
//Path to the MPFR library
MPFR_LIBRARIES:FILEPATH=D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib
MPFR_LIBRARIES_DIR:FILEPATH=D:/winappl/CGAL-3.8/auxiliary/gmp/lib
//OpenGL library for win32
OPENGL_gl_LIBRARY:STRING=opengl32
//GLU library for win32
OPENGL_glu_LIBRARY:STRING=glu32
//path to qt3 include directory
QT3_INCLUDE_DIR:PATH=QT3_INCLUDE_DIR-NOTFOUND
QT3_MOC_EXECUTABLE:FILEPATH=d:/winappl/Qt/4.7.4/bin/moc.exe
QT3_QASSISTANTCLIENT_LIBRARY:FILEPATH=QT3_QASSISTANTCLIENT_LIBRARY-NOTFOUND
//This Library is only needed by and included with Qt3 on MSWindows.
// It should be NOTFOUND, undefined or IGNORE otherwise.
QT3_QTMAIN_LIBRARY:FILEPATH=d:/winappl/Qt/4.7.4/lib/qtmain.lib
QT3_QT_LIBRARY:FILEPATH=QT3_QT_LIBRARY-NOTFOUND
QT3_UIC_EXECUTABLE:FILEPATH=d:/winappl/Qt/4.7.4/bin/uic.exe
QT_ARTHURPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_ARTHURPLUGIN_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/designer/arthurplugin.dll
QT_CONTAINEREXTENSION_PLUGIN_DEBUG:FILEPATH=QT_CONTAINEREXTENSION_PLUGIN_DEBUG-NOTFOUND
QT_CONTAINEREXTENSION_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/designer/containerextension.dll
QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/designer/customwidgetplugin.dll
QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=QT_DBUSCPP2XML_EXECUTABLE-NOTFOUND
QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=QT_DBUSXML2CPP_EXECUTABLE-NOTFOUND
QT_DESIGNER_EXECUTABLE:FILEPATH=D:/winappl/Qt/4.7.4/bin/designer.exe
//The location of the Qt docs
QT_DOC_DIR:PATH=D:/winappl/Qt/4.7.4/doc
//The location of the Qt imports
QT_IMPORTS_DIR:PATH=D:/winappl/Qt/4.7.4/imports
QT_LINGUIST_EXECUTABLE:FILEPATH=D:/winappl/Qt/4.7.4/bin/linguist.exe
QT_LRELEASE_EXECUTABLE:FILEPATH=D:/winappl/Qt/4.7.4/bin/lrelease.exe
QT_LUPDATE_EXECUTABLE:FILEPATH=D:/winappl/Qt/4.7.4/bin/lupdate.exe
//The location of the Qt mkspecs containing qconfig.pri
QT_MKSPECS_DIR:PATH=D:/winappl/Qt/4.7.4/mkspecs
QT_MOC_EXECUTABLE:FILEPATH=D:/winappl/Qt/4.7.4/bin/moc.exe
QT_PHONONWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_PHONONWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_PHONONWIDGETS_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/designer/phononwidgets.dll
//Path to a file.
QT_PHONON_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/phonon
//The Qt PHONON library
QT_PHONON_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/phonon4.lib;debug;D:/winappl/Qt/4.7.4/lib/phonond4.lib
QT_PHONON_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/phonond4.lib
QT_PHONON_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/phonon4.lib
QT_PHONON_QT7_PLUGIN_DEBUG:FILEPATH=QT_PHONON_QT7_PLUGIN_DEBUG-NOTFOUND
QT_PHONON_QT7_PLUGIN_RELEASE:FILEPATH=QT_PHONON_QT7_PLUGIN_RELEASE-NOTFOUND
//The location of the Qt plugins
QT_PLUGINS_DIR:PATH=D:/winappl/Qt/4.7.4/plugins
//Path to a file.
QT_QAXCONTAINER_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/ActiveQt
//The Qt QAXCONTAINER library
QT_QAXCONTAINER_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QAxContainer.lib;debug;D:/winappl/Qt/4.7.4/lib/QAxContainerd.lib
QT_QAXCONTAINER_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QAxContainerd.lib
QT_QAXCONTAINER_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QAxContainer.lib
//Path to a file.
QT_QAXSERVER_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/ActiveQt
//The Qt QAXSERVER library
QT_QAXSERVER_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QAxServer.lib;debug;D:/winappl/Qt/4.7.4/lib/QAxServerd.lib
QT_QAXSERVER_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QAxServerd.lib
QT_QAXSERVER_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QAxServer.lib
QT_QCNCODECS_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/codecs/qcncodecsd4.dll
QT_QCNCODECS_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/codecs/qcncodecs4.dll
QT_QCOLLECTIONGENERATOR_EXECUTABLE:FILEPATH=D:/winappl/Qt/4.7.4/bin/qcollectiongenerator.exe
QT_QCOREWLANBEARER_PLUGIN_DEBUG:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_DEBUG-NOTFOUND
QT_QCOREWLANBEARER_PLUGIN_RELEASE:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_RELEASE-NOTFOUND
QT_QDECLARATIVEVIEW_PLUGIN_DEBUG:FILEPATH=QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-NOTFOUND
QT_QDECLARATIVEVIEW_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/designer/qdeclarativeview.dll
QT_QDECORATIONDEFAULT_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-NOTFOUND
QT_QDECORATIONDEFAULT_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-NOTFOUND
QT_QDECORATIONWINDOWS_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-NOTFOUND
QT_QDECORATIONWINDOWS_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-NOTFOUND
QT_QGENERICBEARER_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/bearer/qgenericbearerd4.dll
QT_QGENERICBEARER_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/bearer/qgenericbearer4.dll
QT_QGIF_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qgifd4.dll
QT_QGIF_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qgif4.dll
QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/graphicssystems/qglgraphicssystemd4.dll
QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/graphicssystems/qglgraphicssystem4.dll
QT_QICO_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qicod4.dll
QT_QICO_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qico4.dll
QT_QIMSW_MULTI_PLUGIN_DEBUG:FILEPATH=QT_QIMSW_MULTI_PLUGIN_DEBUG-NOTFOUND
QT_QIMSW_MULTI_PLUGIN_RELEASE:FILEPATH=QT_QIMSW_MULTI_PLUGIN_RELEASE-NOTFOUND
QT_QJPCODECS_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/codecs/qjpcodecsd4.dll
QT_QJPCODECS_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/codecs/qjpcodecs4.dll
QT_QJPEG_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qjpegd4.dll
QT_QJPEG_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qjpeg4.dll
QT_QKRCODECS_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/codecs/qkrcodecsd4.dll
QT_QKRCODECS_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/codecs/qkrcodecs4.dll
//The qmake executable for the Qt installation to use
QT_QMAKE_EXECUTABLE:FILEPATH=d:/winappl/Qt/4.7.4/bin/qmake.exe
QT_QMNG_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qmngd4.dll
QT_QMNG_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qmng4.dll
QT_QSQLDB2_PLUGIN_DEBUG:FILEPATH=QT_QSQLDB2_PLUGIN_DEBUG-NOTFOUND
QT_QSQLDB2_PLUGIN_RELEASE:FILEPATH=QT_QSQLDB2_PLUGIN_RELEASE-NOTFOUND
QT_QSQLIBASE_PLUGIN_DEBUG:FILEPATH=QT_QSQLIBASE_PLUGIN_DEBUG-NOTFOUND
QT_QSQLIBASE_PLUGIN_RELEASE:FILEPATH=QT_QSQLIBASE_PLUGIN_RELEASE-NOTFOUND
QT_QSQLITE2_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE2_PLUGIN_DEBUG-NOTFOUND
QT_QSQLITE2_PLUGIN_RELEASE:FILEPATH=QT_QSQLITE2_PLUGIN_RELEASE-NOTFOUND
QT_QSQLITE_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/sqldrivers/qsqlited4.dll
QT_QSQLITE_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/sqldrivers/qsqlite4.dll
QT_QSQLMYSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLMYSQL_PLUGIN_DEBUG-NOTFOUND
QT_QSQLMYSQL_PLUGIN_RELEASE:FILEPATH=QT_QSQLMYSQL_PLUGIN_RELEASE-NOTFOUND
QT_QSQLOCI_PLUGIN_DEBUG:FILEPATH=QT_QSQLOCI_PLUGIN_DEBUG-NOTFOUND
QT_QSQLOCI_PLUGIN_RELEASE:FILEPATH=QT_QSQLOCI_PLUGIN_RELEASE-NOTFOUND
QT_QSQLODBC_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/sqldrivers/qsqlodbcd4.dll
QT_QSQLODBC_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/sqldrivers/qsqlodbc4.dll
QT_QSQLPSQL_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/sqldrivers/qsqlpsqld4.dll
QT_QSQLPSQL_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/sqldrivers/qsqlpsql4.dll
QT_QSQLTDS_PLUGIN_DEBUG:FILEPATH=QT_QSQLTDS_PLUGIN_DEBUG-NOTFOUND
QT_QSQLTDS_PLUGIN_RELEASE:FILEPATH=QT_QSQLTDS_PLUGIN_RELEASE-NOTFOUND
QT_QSVGICON_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/iconengines/qsvgicond4.dll
QT_QSVGICON_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/iconengines/qsvgicon4.dll
QT_QSVG_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qsvgd4.dll
QT_QSVG_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qsvg4.dll
QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/designer/qt3supportwidgets.dll
//Path to a file.
QT_QT3SUPPORT_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/Qt3Support
//The Qt QT3SUPPORT library
QT_QT3SUPPORT_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/Qt3Support4.lib;debug;D:/winappl/Qt/4.7.4/lib/Qt3Supportd4.lib
QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/Qt3Supportd4.lib
QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/Qt3Support4.lib
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/accessible/qtaccessiblecompatwidgetsd4.dll
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/accessible/qtaccessiblecompatwidgets4.dll
QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/accessible/qtaccessiblewidgetsd4.dll
QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/accessible/qtaccessiblewidgets4.dll
//Path to a file.
QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=QT_QTASSISTANTCLIENT_INCLUDE_DIR-NOTFOUND
//The Qt QTASSISTANTCLIENT library
QT_QTASSISTANTCLIENT_LIBRARY:STRING=
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-NOTFOUND
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTASSISTANT_INCLUDE_DIR:PATH=QT_QTASSISTANT_INCLUDE_DIR-NOTFOUND
//The Qt QTASSISTANT library
QT_QTASSISTANT_LIBRARY:STRING=
QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND
QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANT_LIBRARY_RELEASE-NOTFOUND
//The Qt QTCLUCENE library
QT_QTCLUCENE_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtCLucene4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtCLucened4.lib
QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtCLucened4.lib
QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtCLucene4.lib
//(This variable does not exist and should not be used)
QT_QTCORE_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtCore
//The Qt QTCORE library
QT_QTCORE_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtCore4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtCored4.lib
QT_QTCORE_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtCored4.lib
QT_QTCORE_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtCore4.lib
//Path to a file.
QT_QTDBUS_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtDBus
//The Qt QTDBUS library
QT_QTDBUS_LIBRARY:STRING=
QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND
QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=QT_QTDBUS_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTDECLARATIVE_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtDeclarative
//The Qt QTDECLARATIVE library
QT_QTDECLARATIVE_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtDeclarative4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtDeclaratived4.lib
QT_QTDECLARATIVE_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtDeclaratived4.lib
QT_QTDECLARATIVE_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtDeclarative4.lib
//Path to a file.
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtDesigner
//The Qt QTDESIGNERCOMPONENTS library
QT_QTDESIGNERCOMPONENTS_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtDesignerComponents4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtDesignerComponentsd4.lib
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtDesignerComponentsd4.lib
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtDesignerComponents4.lib
//Path to a file.
QT_QTDESIGNER_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtDesigner
//The Qt QTDESIGNER library
QT_QTDESIGNER_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtDesigner4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtDesignerd4.lib
QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtDesignerd4.lib
QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtDesigner4.lib
//Path to a file.
QT_QTGUI_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtGui
//The Qt QTGUI library
QT_QTGUI_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtGui4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtGuid4.lib
QT_QTGUI_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtGuid4.lib
QT_QTGUI_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtGui4.lib
//Path to a file.
QT_QTHELP_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtHelp
//The Qt QTHELP library
QT_QTHELP_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtHelp4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtHelpd4.lib
QT_QTHELP_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtHelpd4.lib
QT_QTHELP_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtHelp4.lib
QT_QTIFF_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qtiffd4.dll
QT_QTIFF_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/imageformats/qtiff4.dll
//The Qt QTMAIN library
QT_QTMAIN_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/qtmain.lib;debug;D:/winappl/Qt/4.7.4/lib/qtmaind.lib
QT_QTMAIN_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/qtmaind.lib
QT_QTMAIN_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/qtmain.lib
//Path to a file.
QT_QTMULTIMEDIA_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtMultimedia
//The Qt QTMULTIMEDIA library
QT_QTMULTIMEDIA_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtMultimedia4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtMultimediad4.lib
QT_QTMULTIMEDIA_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtMultimediad4.lib
QT_QTMULTIMEDIA_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtMultimedia4.lib
//Path to a file.
QT_QTNETWORK_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtNetwork
//The Qt QTNETWORK library
QT_QTNETWORK_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtNetwork4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtNetworkd4.lib
QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtNetworkd4.lib
QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtNetwork4.lib
//Path to a file.
QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
//The Qt QTNSPLUGIN library
QT_QTNSPLUGIN_LIBRARY:STRING=
QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTOPENGL_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtOpenGL
//The Qt QTOPENGL library
QT_QTOPENGL_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtOpenGL4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtOpenGLd4.lib
QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtOpenGLd4.lib
QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtOpenGL4.lib
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/graphicssystems/qtracegraphicssystemd4.dll
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/graphicssystems/qtracegraphicssystem4.dll
QT_QTSCRIPTDBUS_PLUGIN_DEBUG:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_DEBUG-NOTFOUND
QT_QTSCRIPTDBUS_PLUGIN_RELEASE:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_RELEASE-NOTFOUND
//Path to a file.
QT_QTSCRIPTTOOLS_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtScriptTools
//The Qt QTSCRIPTTOOLS library
QT_QTSCRIPTTOOLS_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtScriptTools4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtScriptToolsd4.lib
QT_QTSCRIPTTOOLS_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtScriptToolsd4.lib
QT_QTSCRIPTTOOLS_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtScriptTools4.lib
//Path to a file.
QT_QTSCRIPT_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtScript
//The Qt QTSCRIPT library
QT_QTSCRIPT_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtScript4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtScriptd4.lib
QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtScriptd4.lib
QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtScript4.lib
//Path to a file.
QT_QTSQL_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtSql
//The Qt QTSQL library
QT_QTSQL_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtSql4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtSqld4.lib
QT_QTSQL_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtSqld4.lib
QT_QTSQL_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtSql4.lib
//Path to a file.
QT_QTSVG_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtSvg
//The Qt QTSVG library
QT_QTSVG_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtSvg4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtSvgd4.lib
QT_QTSVG_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtSvgd4.lib
QT_QTSVG_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtSvg4.lib
//Path to a file.
QT_QTTEST_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtTest
//The Qt QTTEST library
QT_QTTEST_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtTest4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtTestd4.lib
QT_QTTEST_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtTestd4.lib
QT_QTTEST_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtTest4.lib
//Path to a file.
QT_QTUITOOLS_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtUiTools
//The Qt QTUITOOLS library
QT_QTUITOOLS_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtUiTools.lib;debug;D:/winappl/Qt/4.7.4/lib/QtUiToolsd.lib
QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtUiToolsd.lib
QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtUiTools.lib
QT_QTWCODECS_PLUGIN_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/plugins/codecs/qtwcodecsd4.dll
QT_QTWCODECS_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/codecs/qtwcodecs4.dll
//Path to a file.
QT_QTWEBKIT_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtWebKit
//The Qt QTWEBKIT library
QT_QTWEBKIT_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtWebKit4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtWebKitd4.lib
QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtWebKitd4.lib
QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtWebKit4.lib
//Path to a file.
QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtXmlPatterns
//The Qt QTXMLPATTERNS library
QT_QTXMLPATTERNS_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtXmlPatterns4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtXmlPatternsd4.lib
QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtXmlPatternsd4.lib
QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtXmlPatterns4.lib
//Path to a file.
QT_QTXML_INCLUDE_DIR:PATH=D:/winappl/Qt/4.7.4/include/QtXml
//The Qt QTXML library
QT_QTXML_LIBRARY:STRING=optimized;D:/winappl/Qt/4.7.4/lib/QtXml4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtXmld4.lib
QT_QTXML_LIBRARY_DEBUG:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtXmld4.lib
QT_QTXML_LIBRARY_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/lib/QtXml4.lib
QT_QWEBVIEW_PLUGIN_DEBUG:FILEPATH=QT_QWEBVIEW_PLUGIN_DEBUG-NOTFOUND
QT_QWEBVIEW_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/designer/qwebview.dll
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-NOTFOUND
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-NOTFOUND
QT_RCC_EXECUTABLE:FILEPATH=D:/winappl/Qt/4.7.4/bin/rcc.exe
QT_TASKMENUEXTENSION_PLUGIN_DEBUG:FILEPATH=QT_TASKMENUEXTENSION_PLUGIN_DEBUG-NOTFOUND
QT_TASKMENUEXTENSION_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/designer/taskmenuextension.dll
//The location of the Qt translations
QT_TRANSLATIONS_DIR:PATH=D:/winappl/Qt/4.7.4/translations
QT_UIC3_EXECUTABLE:FILEPATH=D:/winappl/Qt/4.7.4/bin/uic3.exe
QT_UIC_EXECUTABLE:FILEPATH=D:/winappl/Qt/4.7.4/bin/uic.exe
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE:FILEPATH=D:/winappl/Qt/4.7.4/plugins/designer/worldtimeclockplugin.dll
//Enable CGAL component Core
WITH_CGAL_Core:BOOL=ON
//Enable CGAL component ImageIO
WITH_CGAL_ImageIO:BOOL=ON
//Enable CGAL component Qt3
WITH_CGAL_Qt3:BOOL=OFF
//Enable CGAL component Qt4
WITH_CGAL_Qt4:BOOL=ON
//Use the GMP number types if available.
WITH_GMP:BOOL=ON
//Use the LEDA number types if available.
WITH_LEDA:BOOL=OFF
//Select demos
WITH_demos:BOOL=OFF
//Select examples
WITH_examples:BOOL=OFF
//Path to a file.
ZLIB_INCLUDE_DIR:PATH=D:/winappl/zlib/include
ZLIB_LIBRARY:FILEPATH=D:/winappl/zlib/lib/zdll.lib
# INTERNAL cache entries
//Stored GUID
ALL_BUILD_GUID_CMAKE:INTERNAL=442469BC-2DD6-4ABB-847A-FA64D90CCAD2
//Name of all CGAL libraries.
ALL_CGAL_LIBRARIES:INTERNAL=CGAL;CGAL_Core;CGAL_ImageIO;CGAL_Qt3;CGAL_Qt4
//ADVANCED property for variable: Boost_INCLUDE_DIR
Boost_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_LIBRARY_DIRS
Boost_LIBRARY_DIRS-ADVANCED:INTERNAL=1
//The library version string for boost libraries
Boost_LIB_VERSION:INTERNAL=1_47
//Whether the Boost THREAD library found
Boost_THREAD_FOUND:INTERNAL=ON
//ADVANCED property for variable: Boost_THREAD_LIBRARY
Boost_THREAD_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_THREAD_LIBRARY_DEBUG
Boost_THREAD_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_THREAD_LIBRARY_RELEASE
Boost_THREAD_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//The version number for boost libraries
Boost_VERSION:INTERNAL=104700
CGAL_3RD_PARTY_DEFINITIONS:INTERNAL=-DCGAL_NO_AUTOLINK_MPFR;-DCGAL_NO_AUTOLINK_GMP
CGAL_3RD_PARTY_INCLUDE_DIRS:INTERNAL=D:/winappl/CGAL-3.8/auxiliary/gmp/include;D:/winappl/CGAL-3.8/auxiliary/gmp/include;d:/winappl/boost_1_47
CGAL_3RD_PARTY_LIBRARIES:INTERNAL=D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib;psapi.lib
CGAL_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=D:/winappl/CGAL-3.8/auxiliary/gmp/lib;D:/winappl/CGAL-3.8/auxiliary/gmp/lib;d:/winappl/boost_1_47/lib;d:/winappl/boost_1_47/lib;d:/winappl/boost_1_47/lib;d:/winappl/boost_1_47/lib
//ADVANCED property for variable: CGAL_AUTO_LINK_GMP
CGAL_AUTO_LINK_GMP-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CGAL_AUTO_LINK_MPFR
CGAL_AUTO_LINK_MPFR-ADVANCED:INTERNAL=1
CGAL_CFG_ARRAY_MEMBER_INITIALIZATION_BUG:INTERNAL=1
//Result of TRY_COMPILE
CGAL_CFG_ARRAY_MEMBER_INITIALIZATION_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_DENORMALS_COMPILE_BUG:INTERNAL=0
CGAL_CFG_DENORMALS_COMPILE_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG:INTERNAL=0
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_IEEE_754_BUG:INTERNAL=0
CGAL_CFG_IEEE_754_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_ISTREAM_INT_BUG:INTERNAL=0
CGAL_CFG_ISTREAM_INT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_LONGNAME_BUG:INTERNAL=1
CGAL_CFG_LONGNAME_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_MATCHING_BUG_5:INTERNAL=0
CGAL_CFG_MATCHING_BUG_5_COMPILED:INTERNAL=TRUE
CGAL_CFG_MATCHING_BUG_6:INTERNAL=1
CGAL_CFG_MATCHING_BUG_6_COMPILED:INTERNAL=FALSE
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG:INTERNAL=1
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_ARRAY:INTERNAL=0
CGAL_CFG_NO_CPP0X_ARRAY_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_AUTO:INTERNAL=0
CGAL_CFG_NO_CPP0X_AUTO_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_DECLTYPE:INTERNAL=0
CGAL_CFG_NO_CPP0X_DECLTYPE_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES:INTERNAL=1
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS:INTERNAL=1
CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS:INTERNAL=1
CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_INITIALIZER_LISTS:INTERNAL=1
CGAL_CFG_NO_CPP0X_INITIALIZER_LISTS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_ISFINITE:INTERNAL=1
CGAL_CFG_NO_CPP0X_ISFINITE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_LAMBDAS:INTERNAL=0
CGAL_CFG_NO_CPP0X_LAMBDAS_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_LONG_LONG:INTERNAL=0
CGAL_CFG_NO_CPP0X_LONG_LONG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE:INTERNAL=0
CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_TUPLE:INTERNAL=0
CGAL_CFG_NO_CPP0X_TUPLE_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES:INTERNAL=1
CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_LIMITS:INTERNAL=0
CGAL_CFG_NO_LIMITS_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_LOGICAL_OPERATORS_ALTERNATIVES:INTERNAL=1
CGAL_CFG_NO_LOGICAL_OPERATORS_ALTERNATIVES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_MESSAGE_PRAGMA_BUG:INTERNAL=0
CGAL_CFG_NO_MESSAGE_PRAGMA_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_NEXTAFTER:INTERNAL=1
CGAL_CFG_NO_NEXTAFTER_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_STATEMENT_EXPRESSIONS:INTERNAL=1
CGAL_CFG_NO_STATEMENT_EXPRESSIONS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_STL:INTERNAL=0
CGAL_CFG_NO_STL_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_TMPL_IN_TMPL_PARAM:INTERNAL=0
CGAL_CFG_NO_TMPL_IN_TMPL_PARAM_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_TR1_ARRAY:INTERNAL=1
CGAL_CFG_NO_TR1_ARRAY_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_TR1_TUPLE:INTERNAL=1
CGAL_CFG_NO_TR1_TUPLE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG:INTERNAL=1
CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_NUMERIC_LIMITS_BUG:INTERNAL=0
CGAL_CFG_NUMERIC_LIMITS_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG:INTERNAL=0
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG:INTERNAL=0
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_USING_BASE_MEMBER_BUG_2:INTERNAL=0
CGAL_CFG_USING_BASE_MEMBER_BUG_2_COMPILED:INTERNAL=TRUE
CGAL_Core_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Core_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Stored GUID
CGAL_Core_GUID_CMAKE:INTERNAL=70B20BD3-B6CA-4ABE-B70C-38CC65E44704
//Variable hidden from user
CGAL_Core_LIBRARY_NAME:INTERNAL=
CGAL_EXECUTABLE_TARGETS:INTERNAL=
//Stored GUID
CGAL_GUID_CMAKE:INTERNAL=67938715-0341-451D-B7F9-BB96AADB3942
CGAL_ImageIO_3RD_PARTY_DEFINITIONS:INTERNAL=-DCGAL_USE_ZLIB
CGAL_ImageIO_3RD_PARTY_INCLUDE_DIRS:INTERNAL=D:/winappl/zlib/include
CGAL_ImageIO_3RD_PARTY_LIBRARIES:INTERNAL=glu32;opengl32;D:/winappl/zlib/lib/zdll.lib
CGAL_ImageIO_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Stored GUID
CGAL_ImageIO_GUID_CMAKE:INTERNAL=D4810DD7-F96E-405D-8175-035FED56DB93
CGAL_ImageIO_LIBRARY_NAME:INTERNAL=
CGAL_ImageIO_USE_ZLIB:INTERNAL=ON
CGAL_LIBRARY_NAME:INTERNAL=
CGAL_Qt3_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Qt3_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
CGAL_Qt3_LIBRARY_NAME:INTERNAL=
CGAL_Qt4_3RD_PARTY_DEFINITIONS:INTERNAL=-DQT_DLL
CGAL_Qt4_3RD_PARTY_INCLUDE_DIRS:INTERNAL=D:/winappl/Qt/4.7.4/include
CGAL_Qt4_3RD_PARTY_LIBRARIES:INTERNAL=optimized;D:/winappl/Qt/4.7.4/lib/qtmain.lib;debug;D:/winappl/Qt/4.7.4/lib/qtmaind.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtOpenGL4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtOpenGLd4.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtGui4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtGuid4.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtCore4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtCored4.lib;glu32;opengl32
CGAL_Qt4_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Stored GUID
CGAL_Qt4_GUID_CMAKE:INTERNAL=1CEACF0B-9702-4034-A18A-E75A83D7A987
CGAL_Qt4_LIBRARY_NAME:INTERNAL=
//ADVANCED property for variable: CGAL_SONAME_VERSION
CGAL_SONAME_VERSION-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CGAL_SOVERSION
CGAL_SOVERSION-ADVANCED:INTERNAL=1
//This is the cygwin platform.
CGAL_WIN32_CMAKE_ON_CYGWIN:INTERNAL=TRUE
//ADVANCED property for variable: CMAKE_BACKWARDS_COMPATIBILITY
CMAKE_BACKWARDS_COMPATIBILITY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_BUILD_TOOL
CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1
//What is the target build tool cmake is generating for.
CMAKE_BUILD_TOOL:INTERNAL=C:/PROGRA~2/MICROS~2.0/Common7/IDE/devenv.com
//This is the directory where this CMakeCache.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=d:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=8
//Patch version of cmake used to create the current loaded cache
CMAKE_CACHE_PATCH_VERSION:INTERNAL=5
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.8/bin/cmake.exe
//ADVANCED property for variable: CMAKE_CONFIGURATION_TYPES
CMAKE_CONFIGURATION_TYPES-ADVANCED:INTERNAL=1
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.8/bin/cpack.exe
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.8/bin/ctest.exe
//ADVANCED property for variable: CMAKE_CXX_COMPILER
CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1
CMAKE_CXX_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL
CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE
CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_STANDARD_LIBRARIES
CMAKE_CXX_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_COMPILER
CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
CMAKE_C_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_STANDARD_LIBRARIES
CMAKE_C_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE
CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE
//Path to cache edit program executable.
CMAKE_EDIT_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.8/bin/cmake-gui.exe
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Name of generator.
CMAKE_GENERATOR:INTERNAL=Visual Studio 10
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=D:/winappl/CGAL-3.8
//ADVANCED property for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MAKE_PROGRAM
CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=6
//ADVANCED property for variable: CMAKE_RC_COMPILER
CMAKE_RC_COMPILER-ADVANCED:INTERNAL=1
CMAKE_RC_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_RC_FLAGS
CMAKE_RC_FLAGS-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=C:/Program Files (x86)/CMake 2.8/share/cmake-2.8
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//Suppress Warnings that are meant for the author of the CMakeLists.txt
// files.
CMAKE_SUPPRESS_DEVELOPER_WARNINGS:INTERNAL=FALSE
CMAKE_UNAME:INTERNAL=d:/winappl/cygwin/bin/uname.exe
//ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
//Stored GUID
EDIT_CACHE_GUID_CMAKE:INTERNAL=ED3CB418-BFA7-4D11-85E0-BCB8BC2F6983
EXECUTABLE_OUTPUT_PATH:INTERNAL=
//Details about finding OpenGL
FIND_PACKAGE_MESSAGE_DETAILS_OpenGL:INTERNAL=[opengl32][v()]
//Details about finding ZLIB
FIND_PACKAGE_MESSAGE_DETAILS_ZLIB:INTERNAL=[D:/winappl/zlib/lib/zdll.lib][D:/winappl/zlib/include][v1.2.5()]
GMP_COMPILE_RES:INTERNAL=TRUE
GMP_IN_CGAL_AUXILIARY:INTERNAL=TRUE
//Result of TRY_RUN
GMP_RUN_RES:INTERNAL=0
//Generator uses intermediate configuration directory
HAS_CFG_INTDIR:INTERNAL=TRUE
//Stored GUID
INSTALL_GUID_CMAKE:INTERNAL=9684A936-3E7A-4BA8-81C6-47D5EDE37BAA
LIBRARY_OUTPUT_PATH:INTERNAL=D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/lib
MPFR_COMPILE_RES:INTERNAL=TRUE
MPFR_IN_CGAL_AUXILIARY:INTERNAL=TRUE
//Result of TRY_RUN
MPFR_RUN_RES:INTERNAL=0
//ADVANCED property for variable: OPENGL_gl_LIBRARY
OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENGL_glu_LIBRARY
OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1
//Stored GUID
PACKAGE_GUID_CMAKE:INTERNAL=3F3DE125-C975-4190-8261-9CDF11001F77
//ADVANCED property for variable: QT3_INCLUDE_DIR
QT3_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_MOC_EXECUTABLE
QT3_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_QASSISTANTCLIENT_LIBRARY
QT3_QASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_QTMAIN_LIBRARY
QT3_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_QT_LIBRARY
QT3_QT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_UIC_EXECUTABLE
QT3_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
QT4_COMPILE_RES:INTERNAL=TRUE
//Result of TRY_RUN
QT4_RUN_RES:INTERNAL=0
//ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_DEBUG
QT_ARTHURPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_RELEASE
QT_ARTHURPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
QT_BINARY_DIR:INTERNAL=D:/winappl/Qt/4.7.4/bin
//ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_DEBUG
QT_CONTAINEREXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_RELEASE
QT_CONTAINEREXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG
QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE
QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DBUSCPP2XML_EXECUTABLE
QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DBUSXML2CPP_EXECUTABLE
QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DESIGNER_EXECUTABLE
QT_DESIGNER_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DOC_DIR
QT_DOC_DIR-ADVANCED:INTERNAL=1
QT_HEADERS_DIR:INTERNAL=D:/winappl/Qt/4.7.4/include
//ADVANCED property for variable: QT_IMPORTS_DIR
QT_IMPORTS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LIBRARY_DIR
QT_LIBRARY_DIR-ADVANCED:INTERNAL=1
//Qt library dir
QT_LIBRARY_DIR:INTERNAL=D:/winappl/Qt/4.7.4/lib
//ADVANCED property for variable: QT_LINGUIST_EXECUTABLE
QT_LINGUIST_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LRELEASE_EXECUTABLE
QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LUPDATE_EXECUTABLE
QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_MKSPECS_DIR
QT_MKSPECS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_MOC_EXECUTABLE
QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_DEBUG
QT_PHONONWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_RELEASE
QT_PHONONWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_INCLUDE_DIR
QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY
QT_PHONON_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY_DEBUG
QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY_RELEASE
QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_QT7_PLUGIN_DEBUG
QT_PHONON_QT7_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_QT7_PLUGIN_RELEASE
QT_PHONON_QT7_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PLUGINS_DIR
QT_PLUGINS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_INCLUDE_DIR
QT_QAXCONTAINER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_LIBRARY
QT_QAXCONTAINER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_LIBRARY_DEBUG
QT_QAXCONTAINER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_LIBRARY_RELEASE
QT_QAXCONTAINER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_INCLUDE_DIR
QT_QAXSERVER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_LIBRARY
QT_QAXSERVER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_LIBRARY_DEBUG
QT_QAXSERVER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_LIBRARY_RELEASE
QT_QAXSERVER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCNCODECS_PLUGIN_DEBUG
QT_QCNCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCNCODECS_PLUGIN_RELEASE
QT_QCNCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOLLECTIONGENERATOR_EXECUTABLE
QT_QCOLLECTIONGENERATOR_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_DEBUG
QT_QCOREWLANBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_RELEASE
QT_QCOREWLANBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_DEBUG
QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_RELEASE
QT_QDECLARATIVEVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_DEBUG
QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_RELEASE
QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_DEBUG
QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_RELEASE
QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_DEBUG
QT_QGENERICBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_RELEASE
QT_QGENERICBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGIF_PLUGIN_DEBUG
QT_QGIF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGIF_PLUGIN_RELEASE
QT_QGIF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG
QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE
QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QICO_PLUGIN_DEBUG
QT_QICO_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QICO_PLUGIN_RELEASE
QT_QICO_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_DEBUG
QT_QIMSW_MULTI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_RELEASE
QT_QIMSW_MULTI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPCODECS_PLUGIN_DEBUG
QT_QJPCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPCODECS_PLUGIN_RELEASE
QT_QJPCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPEG_PLUGIN_DEBUG
QT_QJPEG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPEG_PLUGIN_RELEASE
QT_QJPEG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QKRCODECS_PLUGIN_DEBUG
QT_QKRCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QKRCODECS_PLUGIN_RELEASE
QT_QKRCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
QT_QMAKE_EXECUTABLE_LAST:INTERNAL=d:/winappl/Qt/4.7.4/bin/qmake.exe
//ADVANCED property for variable: QT_QMNG_PLUGIN_DEBUG
QT_QMNG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QMNG_PLUGIN_RELEASE
QT_QMNG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLDB2_PLUGIN_DEBUG
QT_QSQLDB2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLDB2_PLUGIN_RELEASE
QT_QSQLDB2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_DEBUG
QT_QSQLIBASE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_RELEASE
QT_QSQLIBASE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE2_PLUGIN_DEBUG
QT_QSQLITE2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE2_PLUGIN_RELEASE
QT_QSQLITE2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE_PLUGIN_DEBUG
QT_QSQLITE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE_PLUGIN_RELEASE
QT_QSQLITE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_DEBUG
QT_QSQLMYSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_RELEASE
QT_QSQLMYSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLOCI_PLUGIN_DEBUG
QT_QSQLOCI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLOCI_PLUGIN_RELEASE
QT_QSQLOCI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLODBC_PLUGIN_DEBUG
QT_QSQLODBC_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLODBC_PLUGIN_RELEASE
QT_QSQLODBC_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_DEBUG
QT_QSQLPSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_RELEASE
QT_QSQLPSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLTDS_PLUGIN_DEBUG
QT_QSQLTDS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLTDS_PLUGIN_RELEASE
QT_QSQLTDS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVGICON_PLUGIN_DEBUG
QT_QSVGICON_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVGICON_PLUGIN_RELEASE
QT_QSVGICON_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVG_PLUGIN_DEBUG
QT_QSVG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVG_PLUGIN_RELEASE
QT_QSVG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG
QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE
QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_INCLUDE_DIR
QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY
QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_DEBUG
QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_RELEASE
QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG
QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE
QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR
QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY
QT_QTASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_INCLUDE_DIR
QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY
QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_DEBUG
QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_RELEASE
QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY
QT_QTCLUCENE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_DEBUG
QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_RELEASE
QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_INCLUDE_DIR
QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY
QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY_DEBUG
QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY_RELEASE
QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_INCLUDE_DIR
QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY
QT_QTDBUS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY_DEBUG
QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY_RELEASE
QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_INCLUDE_DIR
QT_QTDECLARATIVE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY
QT_QTDECLARATIVE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_DEBUG
QT_QTDECLARATIVE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_RELEASE
QT_QTDECLARATIVE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY
QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_INCLUDE_DIR
QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY
QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_DEBUG
QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_RELEASE
QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_INCLUDE_DIR
QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY
QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY_DEBUG
QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY_RELEASE
QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_INCLUDE_DIR
QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY
QT_QTHELP_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY_DEBUG
QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY_RELEASE
QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTIFF_PLUGIN_DEBUG
QT_QTIFF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTIFF_PLUGIN_RELEASE
QT_QTIFF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMAIN_LIBRARY
QT_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMAIN_LIBRARY_DEBUG
QT_QTMAIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMAIN_LIBRARY_RELEASE
QT_QTMAIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_INCLUDE_DIR
QT_QTMULTIMEDIA_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY
QT_QTMULTIMEDIA_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_DEBUG
QT_QTMULTIMEDIA_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_RELEASE
QT_QTMULTIMEDIA_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_INCLUDE_DIR
QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY
QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY_DEBUG
QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY_RELEASE
QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_INCLUDE_DIR
QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY
QT_QTNSPLUGIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG
QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE
QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_INCLUDE_DIR
QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY
QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY_DEBUG
QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY_RELEASE
QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_DEBUG
QT_QTSCRIPTDBUS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_RELEASE
QT_QTSCRIPTDBUS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_INCLUDE_DIR
QT_QTSCRIPTTOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY
QT_QTSCRIPTTOOLS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_DEBUG
QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_RELEASE
QT_QTSCRIPTTOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_INCLUDE_DIR
QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY
QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_DEBUG
QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_RELEASE
QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_INCLUDE_DIR
QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY
QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY_DEBUG
QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY_RELEASE
QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_INCLUDE_DIR
QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY
QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY_DEBUG
QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY_RELEASE
QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_INCLUDE_DIR
QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY
QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY_DEBUG
QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY_RELEASE
QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_INCLUDE_DIR
QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY
QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_DEBUG
QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_RELEASE
QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWCODECS_PLUGIN_DEBUG
QT_QTWCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWCODECS_PLUGIN_RELEASE
QT_QTWCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_INCLUDE_DIR
QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY
QT_QTWEBKIT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_DEBUG
QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_RELEASE
QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_INCLUDE_DIR
QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY
QT_QTXMLPATTERNS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG
QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE
QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_INCLUDE_DIR
QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY
QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY_DEBUG
QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY_RELEASE
QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_DEBUG
QT_QWEBVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_RELEASE
QT_QWEBVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_RCC_EXECUTABLE
QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_DEBUG
QT_TASKMENUEXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_RELEASE
QT_TASKMENUEXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TRANSLATIONS_DIR
QT_TRANSLATIONS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_UIC3_EXECUTABLE
QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_UIC_EXECUTABLE
QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//Have symbol Q_WS_MAC
Q_WS_MAC:INTERNAL=
//Have symbol Q_WS_QWS
Q_WS_QWS:INTERNAL=
//Have symbol Q_WS_WIN
Q_WS_WIN:INTERNAL=1
//Have symbol Q_WS_X11
Q_WS_X11:INTERNAL=
//Stored GUID
REBUILD_CACHE_GUID_CMAKE:INTERNAL=EFC2E630-09FD-499C-981A-8AF88DAB776A
//Stored GUID
RUN_TESTS_GUID_CMAKE:INTERNAL=597C5093-508A-4C60-AB3F-650227BF21D3
//Stored GUID
SG_Filter_CMake Rules_GUID_CMAKE:INTERNAL=AB9363E2-B488-4E4E-A498-B881674BEC54
//Stored GUID
SG_Filter_Header
Files_GUID_CMAKE:INTERNAL=EF4D74D6-1194-4C85-8D13-B33684402566
//Stored GUID
SG_Filter_Resources_GUID_CMAKE:INTERNAL=95B5251B-AEB6-46A8-A333-2F29FD835901
//Stored GUID
SG_Filter_Source
Files_GUID_CMAKE:INTERNAL=BC13B852-1122-4C40-B81D-67E931BB2F57
//Stored GUID
ZERO_CHECK_GUID_CMAKE:INTERNAL=5D03C84D-5602-4092-A279-1510E0F4E53F
ZLIB_COMPILE_RES:INTERNAL=TRUE
//ADVANCED property for variable: ZLIB_INCLUDE_DIR
ZLIB_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: ZLIB_LIBRARY
ZLIB_LIBRARY-ADVANCED:INTERNAL=1
//Result of TRY_RUN
ZLIB_RUN_RES:INTERNAL=0
//Stored GUID
demos_GUID_CMAKE:INTERNAL=1142880D-AA2B-4167-83A3-EFDCFFB95F24
//Stored GUID
examples_GUID_CMAKE:INTERNAL=AED709BB-7AE1-48EE-9EBA-A3C458DF6839
//Stored GUID
install_FindCGAL_GUID_CMAKE:INTERNAL=7D012A52-217D-4814-8F9E-21933973CF64
# This files contains definitions needed to use CGAL in a program.
# DO NOT EDIT THIS. The definitons have been generated by CMake at
configuration time.
# This file is loaded by cmake via the command "find_package(CGAL)"
# This file correspond to a possibly out-of-sources CGAL configuration, thus
the actual location
# must be given by the cmake variable or enviroment variable CGAL_DIR.
set(CGAL_CONFIG_LOADED TRUE)
set(CGAL_SOURCE_DIRECTORY "D:/winappl/CGAL-3.8" )
set(CGAL_BINARY_DIRECTORY "D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux" )
set(CGAL_MAJOR_VERSION "3" )
set(CGAL_MINOR_VERSION "8" )
set(CGAL_BUILD_VERSION "" )
set(CGAL_SHARED_LIBS "OFF" )
set(CGAL_CXX_FLAGS_INIT " /DWIN32 /D_WINDOWS /W3 /Zm1000
/EHsc /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
-D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except-" )
set(CGAL_CXX_FLAGS_RELEASE_INIT "/MD /O2 /Ob2 /D NDEBUG" )
set(CGAL_CXX_FLAGS_DEBUG_INIT "/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1" )
set(CGAL_MODULE_LINKER_FLAGS_INIT " /STACK:10000000 /machine:X86 " )
set(CGAL_MODULE_LINKER_FLAGS_RELEASE_INIT "/INCREMENTAL:NO" )
set(CGAL_MODULE_LINKER_FLAGS_DEBUG_INIT "/debug /INCREMENTAL" )
set(CGAL_SHARED_LINKER_FLAGS_INIT " /STACK:10000000 /machine:X86 " )
set(CGAL_SHARED_LINKER_FLAGS_RELEASE_INIT "/INCREMENTAL:NO" )
set(CGAL_SHARED_LINKER_FLAGS_DEBUG_INIT "/debug /INCREMENTAL" )
set(CGAL_BUILD_TYPE_INIT "Release" )
set(CGAL_INCLUDE_DIRS
"D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/include;D:/winappl/CGAL-3.8/include"
set(CGAL_MODULES_DIR "D:/winappl/CGAL-3.8/cmake/modules" )
set(CGAL_LIBRARIES_DIR "D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/lib" )
set(WITH_CGAL "ON")
set(WITH_CGAL_Core "ON")
set(WITH_CGAL_ImageIO "ON")
set(WITH_CGAL_Qt3 "OFF" )
set(WITH_CGAL_Qt4 "ON" )
set(CGAL_LIBRARY "")
set(CGAL_Core_LIBRARY "")
set(CGAL_ImageIO_LIBRARY "")
set(CGAL_Qt3_LIBRARY "" )
set(CGAL_Qt4_LIBRARY "" )
set(CGAL_3RD_PARTY_INCLUDE_DIRS
"D:/winappl/CGAL-3.8/auxiliary/gmp/include;D:/winappl/CGAL-3.8/auxiliary/gmp/include;d:/winappl/boost_1_47"
set(CGAL_3RD_PARTY_DEFINITIONS
"-DCGAL_NO_AUTOLINK_MPFR;-DCGAL_NO_AUTOLINK_GMP" )
set(CGAL_3RD_PARTY_LIBRARIES_DIRS
"D:/winappl/CGAL-3.8/auxiliary/gmp/lib;D:/winappl/CGAL-3.8/auxiliary/gmp/lib;d:/winappl/boost_1_47/lib;d:/winappl/boost_1_47/lib;d:/winappl/boost_1_47/lib;d:/winappl/boost_1_47/lib"
"D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libmpfr-4.lib;D:/winappl/CGAL-3.8/auxiliary/gmp/lib/libgmp-10.lib;psapi.lib"
set(CGAL_Core_3RD_PARTY_INCLUDE_DIRS "" )
set(CGAL_Core_3RD_PARTY_DEFINITIONS "" )
set(CGAL_Core_3RD_PARTY_LIBRARIES_DIRS "" )
set(CGAL_Core_3RD_PARTY_LIBRARIES "" )
set(CGAL_ImageIO_3RD_PARTY_INCLUDE_DIRS "D:/winappl/zlib/include" )
set(CGAL_ImageIO_3RD_PARTY_DEFINITIONS "-DCGAL_USE_ZLIB" )
set(CGAL_ImageIO_3RD_PARTY_LIBRARIES_DIRS "" )
"glu32;opengl32;D:/winappl/zlib/lib/zdll.lib" )
set(CGAL_ImageIO_USE_ZLIB "ON" )
set(CGAL_Qt3_3RD_PARTY_INCLUDE_DIRS "" )
set(CGAL_Qt3_3RD_PARTY_DEFINITIONS "" )
set(CGAL_Qt3_3RD_PARTY_LIBRARIES_DIRS "" )
set(CGAL_Qt3_3RD_PARTY_LIBRARIES "" )
set(CGAL_Qt4_3RD_PARTY_INCLUDE_DIRS "D:/winappl/Qt/4.7.4/include" )
set(CGAL_Qt4_3RD_PARTY_DEFINITIONS "-DQT_DLL" )
set(CGAL_Qt4_3RD_PARTY_LIBRARIES_DIRS "" )
"optimized;D:/winappl/Qt/4.7.4/lib/qtmain.lib;debug;D:/winappl/Qt/4.7.4/lib/qtmaind.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtOpenGL4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtOpenGLd4.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtGui4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtGuid4.lib;optimized;D:/winappl/Qt/4.7.4/lib/QtCore4.lib;debug;D:/winappl/Qt/4.7.4/lib/QtCored4.lib;glu32;opengl32"
set(CGAL_VERSION
"${CGAL_MAJOR_VERSION}.${CGAL_MINOR_VERSION}.${CGAL_BUILD_VERSION}")
set(CGAL_GMP_VERSION "5.0.1")
set(CGAL_MPFR_VERSION "3.0.0")
set(CGAL_AUTO_LINK_GMP "OFF")
set(CGAL_AUTO_LINK_MPFR "OFF")
set(CGAL_USE_FILE "${CGAL_MODULES_DIR}/UseCGAL.cmake" )
if ( CGAL_FIND_REQUIRED )
set( CHECK_CGAL_COMPONENT_MSG_ON_ERROR TRUE )
set( CHECK_CGAL_COMPONENT_ERROR_TYPE FATAL_ERROR )
set( CHECK_CGAL_COMPONENT_ERROR_TITLE "ERROR:" )
else()
if ( NOT CGAL_FIND_QUIETLY )
set( CHECK_CGAL_COMPONENT_ERROR_TYPE STATUS )
set( CHECK_CGAL_COMPONENT_ERROR_TITLE "NOTICE:" )
else()
set( CHECK_CGAL_COMPONENT_MSG_ON_ERROR FALSE )
endif()
endif()
macro(check_cgal_component COMPONENT)
set( CGAL_LIB CGAL${COMPONENT} )
if ( WITH_${CGAL_LIB} )
set( ${CGAL_LIB}_FOUND TRUE )
else()
set( ${CGAL_LIB}_FOUND FALSE )
endif()
if ( "${COMPONENT}" STREQUAL "" )
set( CHECK_${CGAL_LIB}_ERROR_TAIL "" )
else()
set( CHECK_${CGAL_LIB}_ERROR_TAIL " Please configure CGAL using
WITH_${CGAL_LIB}=ON." )
endif()
if ( NOT ${CGAL_LIB}_FOUND AND CHECK_CGAL_COMPONENT_MSG_ON_ERROR )
message( ${CHECK_CGAL_COMPONENT_ERROR_TYPE}
"${CHECK_CGAL_COMPONENT_ERROR_TITLE} The ${CGAL_LIB} library was not
configured.${CHECK_${CGAL_LIB}_ERROR_TAIL}" )
endif()
endmacro()
check_cgal_component("")
foreach( CGAL_COMPONENT ${CGAL_FIND_COMPONENTS} )
check_cgal_component("_${CGAL_COMPONENT}")
endforeach()
# Starting with cmake 2.6.3, CGAL_FIND_COMPONENTS is cleared out when
find_package returns.
# But we need it within UseCGAL.cmake, so we save it aside into another
variable
set( CGAL_REQUESTED_COMPONENTS ${CGAL_FIND_COMPONENTS} )
# Install script for directory: D:/winappl/CGAL-3.8
# Set the install prefix
IF(NOT DEFINED CMAKE_INSTALL_PREFIX)
SET(CMAKE_INSTALL_PREFIX "D:/winappl/CGAL")
ENDIF(NOT DEFINED CMAKE_INSTALL_PREFIX)
STRING(REGEX REPLACE "/$" "" CMAKE_INSTALL_PREFIX "${CMAKE_INSTALL_PREFIX}")
# Set the install configuration name.
IF(NOT DEFINED CMAKE_INSTALL_CONFIG_NAME)
IF(BUILD_TYPE)
STRING(REGEX REPLACE "^[^A-Za-z0-9_]+" ""
CMAKE_INSTALL_CONFIG_NAME "${BUILD_TYPE}")
ELSE(BUILD_TYPE)
SET(CMAKE_INSTALL_CONFIG_NAME "Release")
ENDIF(BUILD_TYPE)
MESSAGE(STATUS "Install configuration: \"${CMAKE_INSTALL_CONFIG_NAME}\"")
ENDIF(NOT DEFINED CMAKE_INSTALL_CONFIG_NAME)
# Set the component getting installed.
IF(NOT CMAKE_INSTALL_COMPONENT)
IF(COMPONENT)
MESSAGE(STATUS "Install component: \"${COMPONENT}\"")
SET(CMAKE_INSTALL_COMPONENT "${COMPONENT}")
ELSE(COMPONENT)
SET(CMAKE_INSTALL_COMPONENT)
ENDIF(COMPONENT)
ENDIF(NOT CMAKE_INSTALL_COMPONENT)
IF(NOT CMAKE_INSTALL_COMPONENT OR "${CMAKE_INSTALL_COMPONENT}" STREQUAL
"Unspecified")
FILE(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/CGAL-3.8" TYPE
FILE FILES
"D:/winappl/CGAL-3.8/AUTHORS"
"D:/winappl/CGAL-3.8/CHANGES"
"D:/winappl/CGAL-3.8/LICENSE"
"D:/winappl/CGAL-3.8/LICENSE.FREE_USE"
"D:/winappl/CGAL-3.8/LICENSE.LGPL"
"D:/winappl/CGAL-3.8/LICENSE.QPL"
ENDIF(NOT CMAKE_INSTALL_COMPONENT OR "${CMAKE_INSTALL_COMPONENT}" STREQUAL
"Unspecified")
"Unspecified")
FILE(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include" TYPE DIRECTORY
FILES "D:/winappl/CGAL-3.8/include/CGAL")
"Unspecified")
"Unspecified")
FILES "D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/include/CGAL")
"Unspecified")
"Unspecified")
FILE(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE PROGRAM FILES
"D:/winappl/CGAL-3.8/scripts/cgal_create_cmake_script"
"D:/winappl/CGAL-3.8/scripts/cgal_make_macosx_app"
"Unspecified")
"Unspecified")
FILE(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib/CGAL" TYPE DIRECTORY
FILES "D:/winappl/CGAL-3.8/cmake/modules/")
"Unspecified")
"Unspecified")
FILE(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib/CGAL" TYPE FILE FILES
"D:/winappl/CGAL-3.8/cmake/modules/UseCGAL.cmake")
"Unspecified")
"Unspecified")
"D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/config/CGALConfig.cmake")
"Unspecified")
"Unspecified")
FILE(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/man/man1" TYPE FILE
FILES "D:/winappl/CGAL-3.8/auxiliary/cgal_create_cmake_script.1")
"Unspecified")
IF(NOT CMAKE_INSTALL_LOCAL_ONLY)
# Include the install script for each subdirectory.
INCLUDE("D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/src/cmake_install.cmake")
ENDIF(NOT CMAKE_INSTALL_LOCAL_ONLY)
IF(CMAKE_INSTALL_COMPONENT)
SET(CMAKE_INSTALL_MANIFEST
"install_manifest_${CMAKE_INSTALL_COMPONENT}.txt")
ELSE(CMAKE_INSTALL_COMPONENT)
SET(CMAKE_INSTALL_MANIFEST "install_manifest.txt")
ENDIF(CMAKE_INSTALL_COMPONENT)
FILE(WRITE
"D:/winappl/CGAL-3.8/BUILD-vs2010-32bit-aux/${CMAKE_INSTALL_MANIFEST}" "")
FOREACH(file ${CMAKE_INSTALL_MANIFEST_FILES})
FILE(APPEND
"${file}\n")
ENDFOREACH(file)
