[cgal-discuss] How to use CGAL functions directly in my source code, without using cmake?
- To:
- Subject: [cgal-discuss] How to use CGAL functions directly in my source code, without using cmake?
- Date: Wed, 5 Oct 2011 12:45:46 -0700 (PDT)
Hello,
I am a new user of CGAL. I want to compute a minimum enclosing rectangle of
image region, using functions convex_hull_2 and min_rectangle_2.
I have tried to use standard examples of CGAL following its manual, and it
works very well (when I use cmake . and make for sources of examples).
However, I need to incorporate and use the CGAL functions directly in our
source code, which contains itself a lot of files with a lot of makefile
etc.
I am trying to do this, but I have not been successful so far.
Could you please give me an advice what is the easiest way to use CGAL
functions in external C++ programs (without using cmake)?
Typically, when some external functions are used, it is enough to add some
#include and then functions can be used. It would be great if you explain me
a similar way for using CGAL functions. In other word, what I could insert
directly in my *.h and *.cc files to use convex_hull_2 and min_rectangle_2
functions?
Thank you very much in advance for your help!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-CGAL-functions-directly-in-my-source-code-without-using-cmake-tp3875930p3875930.html
- [cgal-discuss] How to use CGAL functions directly in my source code, without using cmake?, Yuliya Tarabalka, 10/05/2011
- Re: [cgal-discuss] How to use CGAL functions directly in my source code, without using cmake?, Josh Stratton, 10/05/2011
- [cgal-discuss] Re: How to use CGAL functions directly in my source code, without using cmake?, Yuliya Tarabalka, 10/05/2011
- Re: [cgal-discuss] Re: How to use CGAL functions directly in my source code, without using cmake?, Sebastien Loriot (GeometryFactory), 10/06/2011
