Re: [cgal-discuss] How to use CGAL functions directly in my source code, without using cmake?
- To:
- Subject: Re: [cgal-discuss] How to use CGAL functions directly in my source code, without using cmake?
- Date: Wed, 5 Oct 2011 14:03:48 -0700
How have you not been successful? What kind of build errors are you getting?
> I am a new user of CGAL. I want to compute a minimum enclosing rectangle of
> image region, using functions convex_hull_2 and min_rectangle_2.
> I have tried to use standard examples of CGAL following its manual, and it
> works very well (when I use cmake . and make for sources of examples).
> However, I need to incorporate and use the CGAL functions directly in our
> source code, which contains itself a lot of files with a lot of makefile
> etc.
> I am trying to do this, but I have not been successful so far.
> Could you please give me an advice what is the easiest way to use CGAL
> functions in external C++ programs (without using cmake)?
> Typically, when some external functions are used, it is enough to add some
> #include and then functions can be used. It would be great if you explain me
> a similar way for using CGAL functions. In other word, what I could insert
> directly in my *.h and *.cc files to use convex_hull_2 and min_rectangle_2
> functions?
> Thank you very much in advance for your help!
> View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/How-to-use-CGAL-functions-directly-in-my-source-code-without-using-cmake-tp3875930p3875930.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] How to use CGAL functions directly in my source code, without using cmake?, Yuliya Tarabalka, 10/05/2011
- Re: [cgal-discuss] How to use CGAL functions directly in my source code, without using cmake?, Josh Stratton, 10/05/2011
- [cgal-discuss] Re: How to use CGAL functions directly in my source code, without using cmake?, Yuliya Tarabalka, 10/05/2011
- Re: [cgal-discuss] Re: How to use CGAL functions directly in my source code, without using cmake?, Sebastien Loriot (GeometryFactory), 10/06/2011
