- To:
- Subject: [cgal-discuss] Re: Converting polygon into mesh
- Date: Tue, 11 Oct 2011 02:08:30 -0700 (PDT)
Thanks! But one thing about the constrained delaunay triangulation is that, I won't be able to mapped the triangulated face back to the original polygon, am I right? Any idea how to solve this?
On Tue, Oct 11, 2011 at 4:59 PM, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
The first thing to do is to compute snap rounded version of your
polygons and then process them. You will avoid degenerate cases handling.
I have no idea what is the expected output but your either use a
Constrained Delaunay Triangulation or an arrangement to compute one.
Relevant documentation pages:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_36.8
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Snap_rounding_2/Chapter_main.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2/Chapter_main.html
Sebastien.
Graviton wrote:> Sent from the cgal-discuss mailing list archive at Nabble.com.
> I have a lot of polygons. Ideally, all the polygons must not overlap one
> other, but they can be located adjacent to one another. You can assume that
> these polygons represent countries on a map, and I import these polygons
> from a drawing. Due to rounding errors, I would have to allow for slight
> polygon overlap ( defined by a certain tolerance) because all these polygons
> are obtained from user hand drawing input, which is not as machine-precised
> as I want them to be.
> My question is how to convert these polygons into mesh ( with vertexes and
> faces) and at the same time, one still knows which face it belongs to in the
> original polygon. Any idea how to proceed with this?
> My current idea is that I would
> 1. create one arrangement for each polygon ( a country), tag the faces in
> the arrangement, see whether it is an unbounded face, or a bounded one. So
> that each bounded face, I can still keep track it back to the original
> 2. overlay all the arrangement together, and obtain an arrangement. Inside
> this arrangement there will be a lot of faces, some of the faces are
> correctly belonged to the only 1 face, some of the face is a result of two
> polygon slightly overlapped one another.
> 3. After obtaining the faces, I will use snap rounding to clear off all the
> sliver (http://en.mimi.hu/gis/sliver_polygon.html) and maybe eliminate a few
> of the faces resulting from two polygon overlapped one another. This should
> properly clean up the topology
> 4. Now all the polygons are in proper topology, i.e, no more sliver, no more
> overlapped polygon, I can then collect the points and the face to construct
> a mesh.
> What do you think about the above approach? Or is there any other more
> direct way of doing things?
> This is a SO post, asking about the same thing.
> http://stackoverflow.com/questions/7495487/convert-polygons-into-mesh
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Converting-polygon-into-mesh-tp3893218p3893218.html
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/Converting-polygon-into-mesh-tp3893218p3893239.htmlTo unsubscribe from Converting polygon into mesh, click here.
View this message in context: Re: Converting polygon into mesh
- [cgal-discuss] Converting polygon into mesh, Graviton, 10/11/2011
- Re: [cgal-discuss] Converting polygon into mesh, Sebastien Loriot (GeometryFactory), 10/11/2011
- [cgal-discuss] Re: Converting polygon into mesh, Graviton, 10/11/2011
- Re: [cgal-discuss] Re: Converting polygon into mesh, Sebastien Loriot (GeometryFactory), 10/11/2011
- Re: [cgal-discuss] Re: Converting polygon into mesh, Efraim Fogel, 10/11/2011
