- To: Winnie Hellmann <>
- Cc: , Efraim Fogel <>
- Subject: Re: [cgal-discuss] Point inside Arrangment
- Date: Fri, 14 Oct 2011 11:53:14 -0400
Hi Winnie,
Thanks! I really like that approach - assuming that location is linear
complexity. Would a comparison like arr.unbounded_face() == e.face() be
sufficient for that check? I.e. is Face_handle meant to be equal to all
other handles pointing to the same face?
Yes - the handles are sort of like pointers in that sense - they give you good identity checks.
Tagging the holes was one of my first ideas, but actually the
Arrangement_2 structure is given - so I can't add tags/additional data
to faces.
One other option: create a hash table or map from face handle to your meta data - if you are doing multiple queries, you build the hash table once, find the face, and know if you are in.
cheers
be
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://www.x-plane.com/blog/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Point inside Arrangment, Winnie Hellmann, 10/05/2011
- Re: [cgal-discuss] Point inside Arrangment, Ben Supnik, 10/05/2011
- Re: [cgal-discuss] Point inside Arrangment, Winnie Hellmann, 10/14/2011
- Re: [cgal-discuss] Point inside Arrangment, Ben Supnik, 10/14/2011
- Re: [cgal-discuss] Point inside Arrangment, Winnie Hellmann, 10/18/2011
- Re: [cgal-discuss] Point inside Arrangment, Efraim Fogel, 10/06/2011
