- To:
- Subject: [cgal-discuss] Point inside Arrangment
- Date: Wed, 05 Oct 2011 17:19:42 +0200
Hi list!
Is there a way to find out whether a point is in the interior of a polygon (with holes) stored in an 2D arrangement? I.e. I want to determine if the point is inside the outer boundary of an arrangement, but not inside any of it's holes. I assume that all arrangements I want to process are actually polygons with holes (so no crossing edges, no isolated vertices, only closed components).
I thought about vertical ray shooting, but since it does not return the feature a query point is located nor all edges/vertices above or below, I can't count the intersected CCBs that way. I can't make multiple ray shoots either since the total query should be of linear complexity.
Also I thought of checking whether the point is to the left of every edge in the arrangement. But since I can not decide if an edge belongs to a hole (or can I?), I don't know when the point has to be on the right side (as far as I know CCBs are always counter-clock-wise).
I could also do point location, but as far as I know all point location algorithms in CGAL that can handle points outside the convex hull of the arrangement have more than linear complexity.
Can anybody give me a hint on what to do? Obviously copying all my stuff into a Polygon_with_holes_2 just for the check is not a good idea when it comes to multiple hundreds of vertices...
Thanks in advance!
Winnie
- [cgal-discuss] Point inside Arrangment, Winnie Hellmann, 10/05/2011
- Re: [cgal-discuss] Point inside Arrangment, Ben Supnik, 10/05/2011
- Re: [cgal-discuss] Point inside Arrangment, Winnie Hellmann, 10/14/2011
- Re: [cgal-discuss] Point inside Arrangment, Ben Supnik, 10/14/2011
- Re: [cgal-discuss] Point inside Arrangment, Winnie Hellmann, 10/18/2011
- Re: [cgal-discuss] Point inside Arrangment, Efraim Fogel, 10/06/2011
